#1 |
lcash: ProjPost Class compile error
Источник: http://blogs.msdn.com/lcash/archive/...ile-error.aspx
============== If you are using the AX 2009 Refresh 2 demo VM you may want to correct a line of code in the ProjPost class if you are using Projects and Project Time Sheets. 1. Press CRTL+D to open the AOT. Expand Classes. ![]() 2. Navigate down to ProjPost. ![]() 3. Expand to show the ClassDeclaration. ![]() 4. Right Click on ClassDeclaration. Select Compare. ![]() 5. When the compare tool opens. Click the Compare button to compare the default USR layer to the SYP layer. ![]() 6. This will show one line of code that needs to be in the USR layer. Which is a variable declaration for “skipCheckLedgerTransDate”. Click the Arrow control to add that to the USR layer. The colour will change from blue. ![]() 7. Close the Compare window. Click Save and Click Compile from the AOT toolbar. ![]() 8. The code should now compile without error. ![]() Cheers Lachlan Original post at http://blogs.msdn.com/lcash/ Источник: http://blogs.msdn.com/lcash/archive/...ile-error.aspx
