Старый 07.07.2011, 22:12   #1
25,643 / 848 (80) +++++++
palleagermark: Upper- / lowercase oddity in AIF
Источник: http://palleagermark.blogspot.com/20...ty-in-aif.html
Have you ever wondered why the name of batch id tag must start with a capital letter, i.e. , when using the InventDim table in an AIF service? The field in the table starts with a lowercase i.
Well, the reason is that AIF uses the names of the methods in the AX class (AxInventDim in this case) for the naming in the schema and of other artifacts it generates. On the AX class the method for this field is named “parmInventDimId”. So here the name starts with a capital letter.
Okay, that’s not really very odd and you could probably have figured this out just by making a qualified guess.
But then, why must the tag for the Serial Id start with a lower case s? The field name in the table starts with a lowercase s, and the method name is “parmInventSerialId”. So according to the logic above, the Serial Id tag should also start with an uppercase character.
This is where it gets interesting. In the \Classes\AxInternalBase\parmMethods method AX generates a list of fieldnames based on the parm methods of the AX class. The underlying class handing out the names is DictClass.
DictClass actually returns a wrong name, or at least not what you see in the AOT, for the parmInventSerialId method. It returns the name as parminventSerialId, which matches the casing of the table field and, voila, the tag can be named exactly as the table field.
Here is a job showing the names handed out by DictClass, along with the AOT names:
static void AIF(Args _args)
SysDictClass dc = new SysDictClass(5790);
Map methods;
MapEnumerator me;
methods = dc.objectMethods2ClassId(true);
me = methods.getEnumerator();
while (me.moveNext())
if (substr(me.currentKey(),1,strlen('parm')) == 'parm')
info (me.currentKey());
axinthefield: The AIF processing services used by each of the AIF adapters in AX 2009 Blog bot DAX Blogs 0 27.05.2011 05:12
ukax: Application Integration Framework (AIF) Document Services Workshop Blog bot DAX Blogs 0 24.01.2011 20:11
daxdilip: How to: Configure Dynamics AX AIF Services to listen for SSL Requests (https) Blog bot DAX Blogs 0 23.01.2011 10:12
dynamics-ax-dev: Copying a Production Environment into a Development/Test Environment Blog bot DAX Blogs 0 02.12.2010 00:11
Dianne Siebold: AIF Top Ten Blog bot DAX Blogs 1 22.04.2008 11:19
Часовой пояс GMT +3, время: 03:52.
