#1 |
axblog4u: Dynamics AX2012: Table Full Text Indexes
Источник: http://axblog4u.wordpress.com/2011/0...-text-indexes/
============== Microsoft Dynamics AX 2012 provides full-text functionality that enables Microsoft Dynamics AX to search business data over a large volume of text data or documents. Please refer the following link which explains on the same. http://dynamicsaxgyan.wordpress.com/.../#comment-203/ Also refer ‘AX Wonders’ blog which explains on setting up ‘Full Text Index’ Setup in SQL Server 2008 R2 http://axwonders.blogspot.com/2011/0...ch-setup.html/ ![]() Example: X++: /* Two important rules for creating Full Text Indexes [Technet] TableGroup property. A table can have a full text index only if the TableGroup property is set to Main or Group on the table. A full text index can only be created on a table with RecId index. So make sure 'CreateRecIdIndex' property flag on table is set to Yes */ static void FullTextIndexesDemo() { Query query = new Query(); QueryBuildDataSource queryBuildDatasource; QueryRun queryRun; QueryBuildRange queryRange; FullTextIndexesDemo fullTextIndexes; queryBuildDatasource = query.addDataSource(tableNum(FullTextIndexesDemo)); queryRange = queryBuildDatasource.addRange(fieldNum(FullTextIndexesDemo, AxVersion)); queryRange.rangeType(QueryRangeType::FullText); /* [Technet] Space characters are treated as implicit Boolean OR operators. There is a space character in the string parameter in call queryBRange4.value("dynamics 0");. */ queryRange.value('dynamics 0'); queryRun = new QueryRun(query); while (queryRun.next()) { fullTextIndexes = queryRun.get(tableNum(FullTextIndexesDemo)); Debug::printTab(DebugPrintTab::ActiveX, fullTextIndexes.AxVersion); } } ![]() Источник: http://axblog4u.wordpress.com/2011/0...-text-indexes/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 26.09.2011 в 13:44. Причина: оформление |
