#1 |
emeadaxsupport: How to print BOL from Transportation Management without using Warehouse Management
Источник: http://blogs.msdn.com/b/axsupport/ar...anagement.aspx
============== I have recently worked with partners and customers utilizing Transportation Management but without intending to use Warehouse Management. There were general concerns with this is there are functions within Transportation Management that seemingly assume that correlating Warehouse Management Setup and Configuration be intact. For example, assume that you want to utilize Rating and routing functionality in Transportation Management to generate the Bill of Lading without having to use Warehouse Management work. Consider the following processes deployed in an attempt to accomplish this scenario:
The concern at this point is that you'd have to go through the process of creating Warehouse Management Work and completing the Work to simply create a WHSSHIPMENTTABLE record so that a Bill of Lading could be generated. Remember, the whole idea here is that we don't want to be forced to have to complete Warehouse Management work as the idea is that we don't want to even use Warehouse Management processes. WORKAROUND: In order to print a Bill of Lading without having to fully utilize Warehouse Management processes, you can take an approach of: 1. Assign a Staging location type and Final shipping location type in Warehouse Management parameters. (NOTE: If one does not exist, you will need to simply create a Location type in Warehouse management | Setup | Warehouse setup | Location types.)\ 2. After confirming the Outbound Shipment from the Load Planning Workbench form, you simply have to click the Release | Release to Warehouse button. This will prompt an InfoLog suggesting that a Shipment record has been created. (NOTE: This action itself creates a record in WHSSHIPMENTTABLE. This does not create Work in Warehouse Management, so nothing further is needed in Warehouse Management) 3. Because a record now exists in WHSSHIPMENTTABLE, you can successfully print the Bill of Lading without requiring additional unnecessary Warehouse Management processes/steps. RECAP: In order to print the Bill of Lading without requiring Warehouse Management Work be performed, you simply:
