02.03.2016, 16:11 | #1 |
kurthatlevik: AX RTW – Hack to enable configuration mode
Источник: https://kurthatlevik.wordpress.com/2...guration-mode/
============== When downloading the AX RTW local VM from connect, you often want to disable some configuration keys. (Like catch weight etc). But now you will see the following warning; “This form is read-only unless the system is in the maintenance mode. Maintenance mode can be enabled in this environment by running maintenance job from LCS, or using Deployment.Setup tool locally” This warning is to prevent that configurations are enables/disabled, and that the system is set in maintenance mode. There are 2 ways of dealing with this.
After that, you can change configurations. But make sure you never EVER do this in a production environment! Hacking DAX’ing J Источник: https://kurthatlevik.wordpress.com/2...guration-mode/
