Старый 02.09.2017, 09:41   #1
Sådan nåede Damgaard-brødrene milliarden: Man skal være god til sprint og maraton
В своем интервью говорится, что при покупке Дамгаарда Microsoft давал на 36% больше, чем стоили акции.
Были времена...
http://www.dr.dk/nyheder/penge/saada...int-og-maraton
Последний раз редактировалось mazzy; 02.09.2017 в 09:44.
Старый 02.09.2017, 15:15   #2
ax_mct is offline
ax_mct
2,548 / 1091 (0) ++++++++
Since then, the two brothers have engaged in a large number of projects and both got a few blows over the spine when the financial crisis hit Denmark hard in 2008.
It also made Erik Damgaard return to the roots and is launching an accounting program reminiscent of what the brothers launched last century.
If you are having a dream of running out as an entrepreneur, then the advice of the two brothers is heard:
- It is important to test the hypotheses of one. It's important to find out if it's up to date. But it is also important that you change direction and correct if it does not. There are too many who hold a too rigid attitude. We lived after the mantra 'Fail fast, learn Quick'. We were directed quickly to. It was characteristic of Damgaard, says Preben Damgaard.
Интересно что за другой продукт он запустил после 2008. И совет очень значимый.
Старый 02.09.2017, 18:16   #3
http://www.uniconta.com/
Старый 03.09.2017, 16:59   #4
ax_mct is offline
ax_mct
А интересно!
100% CLOUD BASED ERP SYSTEM
Но
It is installed on your PC, and stores all data in the cloud. It is an approach that provides maximum speed and worker mobility with no waiting periods. You are also not dependent on browsers that are susceptible to lock you out, “forget data” or disconnecting you.
Uniconta is built on a straightforward system comprising the all-essential tools and core functionalities of a working application within a modern and customisable Microsoft front- and backend environment.
The Uniconta client is a normal Windows program developed using .NET. It uses WPF (Windows Presentation Foundation) for its user interface. Since the client executes on the user’s PC, we can take full advantages of the many possibilities that .NET offers. Generally, a .NET program consists of several DLL’s (Dynamic Linked Library), that are linked
Старый 03.09.2017, 18:58   #5
Ну, а что тут странного? Приложение в Виндоус - это твое окно в клауд
Нигде выше не написано, что там есть какая-либо логика на клиентской стороне - просто показывает твои контрольчики и все. Вся логика - на сервере, который в клауде, вот и 100% можно смело утверждать.
Старый 04.09.2017, 00:42   #6
ax_mct is offline
ax_mct
Тонкий но desktop клиент вместо браузера.
Подход этого нового продукта Damgaard намного более разумен чем подход AX7.
Сам по себе web-интерфейс может быть ни чуть не хуже но если это web-приложение с самого начала на нормальном фрэймворке.
Странным показалось почему стартап использует Microsoft, но потом понял что возможно ему понравилось продавать это в Microsoft
Старый 04.09.2017, 10:11   #7
Удвой Покуров is offline
Удвой Покуров
461 / 228 (8) ++++++
Вы много видели коммерческих компаний, которые используют что-то иное? Если компания хочет окупиться - она делает продукт для самых распространенных систем. Мобильные приложения пишут под ios и android, и странной будет компания, которая начнет с какой-либо еще, пусть даже замечательной, ос. И успех подобного стартапа будет крайне сомнительным. Так почему Вас смущает, что они начали с Windows?
Старый 04.09.2017, 20:43   #8
ax_mct is offline
ax_mct
Сообщение от Удвой Покуров Посмотреть сообщение
Коммерческих компаний использующих что-то иное чем продукты от Microsoft - более чем достаточно. Доля Microsoft в enterprise секторе далеко не доминирующая.
Если бы Даамгард не преследовал целей "помочь" Microsoft то выбор технологий был бы не в пользу
Microsoft. Реальная кросс-платформенность других технологий прекрасно охватывает и Windows.
Xamarin/Mono не завоевали доверия рынка.
Для меня этот новый продукт выглядит ответом на AX7 со стороны Даамгард чтобы показать как надо делать правильно. Возможно в результате некоего инсайта который нам недоступен.
Чудес не бывает, а клиенту ERP надо богатый и быстрый интерфейс. Что в принципе возможно на чистом web-приложении, но таковым АХ7 не является.
Старый 04.09.2017, 17:37   #9
AlexeyS is offline
AlexeyS
404 / 339 (12) ++++++
очевидно, что если desktop-приложение это только интерфейсная часть, то ничего не мешает сделать клиента на Android или IOS и сделать его намного более удобным и отзывчивым, чем любой клиент в браузере.
Часовой пояс GMT +3, время: 08:53.
