Старый 05.08.2008, 05:18   #1
25,626 / 848 (80) +++++++
C# and AX Development: Using ADO for interfacing AX with an external database
Источник: http://olondono.blogspot.com/2008/08...x-with_04.html
If we need to interface any external database with Dynamics AX, we can achieve this task by using ADO and its AX available classes: CCADOConnection, CCADORecordSet, CCADOFields, CCADOField and CCADOCommand. Here an example:
static void ADOTestJob(Args _args){ CCADOConnection ccConnection; CCADOCommand ccCommand; CCADORecordSet ccRecordset; CCADOFields ccFields; str st; str data1; int data2; ; ccConnection = new CCADOConnection(); // Setting the connection string ccConnection.connectionString(StrFmt('Provider=SQLOLEDB.1;Persist Security Info=False;User ID=%3;Password=%4;Initial Catalog=%2;Data Source=%1' , 'servername' // Server's IP or name , 'database' // Database or catalog , 'user' // Username , 'pwd' // Password )); // Open the connection ccConnection.open(); // Preparing the query st = "SELECT * FROM mytable"; // Recordset object creation ccRecordset = new CCADORecordSet(); // Executing the query ccRecordset.open( st, ccConnection ); // Reading data while (!ccRecordset.EOF()) { ccFields = ccRecordset.fields(); // We can access fields either by name or by Index data1 = ccFields.itemName("FIELD1").value(); data2 = ccFields.itemIdx(1).value(); info(strfmt("Data %1, %2", data1, data2)); // Read next record ccRecordset.moveNext(); } // Closing the connection ccRecordset.close(); ccConnection.close();}
If we need to execute something (an UPDATE, DELETE, etc.), we can use the CCADOCommand:
void ExecuteSQLExt(str sql){ // Creating the ADO Command object ccCommand = new CCADOCommand(); // Associate it with an existing opened connection ccCommand.activeConnection(ccConnection); // Executing the command ccCommand.commandText(SQL); ccCommand.execute();}
NOTE: For working with ADO constants like cursor types (adOpenForwardOnly, adOpenKeyset, adOpenDynamic, adOpenStatic), we only need to include the macro CCADO (#CCADO) where they are defined.
Часовой пояс GMT +3, время: 11:45.
