Старый 17.04.2009, 11:43   #1
Camena is offline
Camena
! Ошибка MSCRMAsyncService
Добрый день!
С каких-то пор в Application логах часто стала появляться следующая ошибка:
Host... a database operation failed while processing organization d67f7a7f-d5fc-491f-afcb-16ed3d90df3e. Will retry 12 times. Exception: System.Data.SqlClient.SqlException: Transaction (Process ID 82) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe)
at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
at Microsoft.Crm.CrmDbConnection.InternalExecuteNonQuery(IDbCommand command)
at Microsoft.Crm.CrmDbConnection.ExecuteNonQuery(IDbCommand command, Boolean impersonate)
at Microsoft.Crm.CrmDbConnection.ExecuteNonQuery(IDbCommand command)
at Microsoft.Crm.Asynchronous.DataAccessSharedBase.ExecuteSqlCommand(IDbCommand command, Nullable`1 expectedAffectedRecords)
at Microsoft.Crm.Asynchronous.QueueDataAccess.UpdateStateAndStatusInternal(Guid eventId, Int32 newState, Int32 newStatus, DateTime nextOccurrence, Boolean retryOperation, Int32 currentRetryCount, Int32 errorCode, String errorMessage, Boolean clearData, Boolean removeEvent, Int32 operationType)
at Microsoft.Crm.Asynchronous.QueueDataAccess.UpdateStateAndStatusCommand.InternalExecute()
at Microsoft.Crm.Asynchronous.QueuedDatabaseCommand.Execute(QueueManager queueManager)
Причина, по которой ошибки возникают, мне непонятна.
Система использует кластерную схему серверов. Может ли причина быть в некорректной настройке кластеров?
Помогите разобраться.
Спасибо.
Последний раз редактировалось Camena; 17.04.2009 в 11:46.
Старый 17.04.2009, 14:01   #2
maxim_ufa is offline
maxim_ufa
Вы 3 Rollup ставили?
Старый 17.04.2009, 14:29   #3
Camena is offline
Camena
Сообщение от maxim_ufa Посмотреть сообщение
Да, UR3 поставлен.
Старый 17.04.2009, 17:39   #4
slivka_83 is offline
slivka_83
Консультант-джедай
Аватар для slivka_83
1,683 / 374 (16) ++++++
Ручные действия из третьего ролапа выполняли?
Экстремал и буду экстремать!
Блога
Старый 17.04.2009, 17:51   #5
Camena is offline
Camena
Что вы подразумеватете под ручными действиями?
Старый 17.04.2009, 18:06   #6
maxim_ufa
Сообщение от Camena Посмотреть сообщение
Добрый день!
С каких-то пор в Application логах часто стала появляться ....
Может после каких-то конкретных манипуляций? И скорее всего данная ошибка появляется периодически...
Включите трасировку (вот тут написано как), возможно станет ясней, из-за чего возникает эта ошибка.
А еще посмотрите тут, тут и тут.
По этим ссылкам описано конечно не решение ваших проблем, но посмотреть будет полезно... потому как ошибка ваша скорее всего связана с workflow...
За это сообщение автора поблагодарили: Camena (1).
Старый 17.04.2009, 18:08   #7
maxim_ufa
Про ручные действия почитайте в этой теме
Там и нужные ссылки найдете, bstan вроде писал.
Последний раз редактировалось maxim_ufa; 17.04.2009 в 18:10.
Старый 17.04.2009, 18:33   #8
Camena is offline
Camena
Спасибо за ссылки!
Ручные действия, если подразумеваетсячистка базы, то они сделаны.
Старый 18.04.2009, 12:17   #9
Camena is offline
Camena
Ничего не помогает! По-прежнему в массовых количествах пишутся в лог эти ошибки!
Старый 20.04.2009, 15:20   #10
maxim_ufa
А что трасировка показывает?
Старый 21.04.2009, 16:40   #11
Camena is offline
Camena
Трассировка показывает наличие ошибки при попытке обновения таблицы AsyncOperationBase.
Тех. поддержка MS заявляет, что проблема вызвана не самим CRM, а кором сервера.
В общем, разбор полетов в самом разгаре...
Старый 30.04.2009, 10:03   #12
Camena is offline
Camena
Проблема массового возникновения deadlock-ов заключалась в некорректной установке UR3, которая проводилась админами со стороны заказчика. Были сделаны откаты, чистки таблиц и поправки в реестре. Однако в целом утранить deadlock-и не удалось, просто произошло общее снижение появления количества таких ошибок в Application Log. Нужно разбираться дальше...
Старый 30.04.2009, 10:18   #13
slivka_83
Консультант-джедай
долго думал как можно криво поставить ролап... там вроде кроме кнопко некст ничего нету
Блога
Старый 30.04.2009, 14:40   #14
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Есть люди которые думают "чего-то он повис, а не нажать ли мне Cancel?". Вот так они и заканчивают потом.
Старый 30.04.2009, 21:10   #15
Camena is offline
Camena
crm, ошибка
Модуль "Маркетинг" - ОШИБКА с действиями кампаний nataly_veksler Dynamics CRM: Разработка 5 06.11.2009 00:48
Ошибка при публикации бизнес-процесса Верба Dynamics CRM: Администрирование 2 27.03.2009 16:18
Ошибка при загрузке функций Microsoft Dynamics CRM Talisman2005 Dynamics CRM: Администрирование 7 26.08.2008 21:21
Ошибка при добавлении отчета e.pasechny Dynamics CRM: Администрирование 5 11.12.2007 14:00
Ошибка при установке MS CRM Outlook клиента flay Dynamics CRM: Администрирование 0 29.06.2006 10:16
Часовой пояс GMT +3, время: 00:20.
