Старый 19.02.2010, 05:07   #1
25,643 / 848 (80) +++++++
emeadaxsupport: You get a warning message when deploying the AX 2009 smmOpportunityReports report library
Источник: http://blogs.msdn.com/emeadaxsupport...t-library.aspx
When deploying the AX 2009 smmOpportunityReports using the Reports Deployment tool or directly from the AOT, you may get the following warning:
One or more libraries built with warnings. Please see MSBuild log at C:\Users\\AppData\Local\Temp\1\tmp98ED.tmp
Deploying 1 data source(s) and 2 design(s) in 3 culture(s) (7 item(s) total)...
Deployment done at 13:25:38. Duration: 00:00:23.5803347
The deployment log file can be found at "C:\Users\\AppData\Local\Temp\1\tmp1319.txt"
(Note: any random tmp filename will be generated). Checking the .tmp file that is specified in the warning in notepad reveals the following warning:
Target CoreCompile:
C:\Users\\AppData\Local\Temp\1\tmp1329.tmp\smmOpportunityReports\smmPipelineMonthOverMonthClosingTrend.moxl : warning AX3020: The data method 'GetColor' in class 'smmPipelineMonthOverMonthClosingTrend' is not present in the model.
Done building target "CoreCompile" in project "smmOpportunityReports.dynamicsproj".
Done building project "smmOpportunityReports.dynamicsproj". Build succeeded.
1 Warning(s)
0 Error(s)
You can safely ignore this warning. There is a code fragment left behind in the smmPipelineMonthOverMonthClosingTrend.cs file which declares a GetColor() method but it is actually not exposed or used in the report library model.
emeadaxsupport: Proxy settings can interfere Dynamics AX 2009 report deployment Blog bot DAX Blogs 0 20.01.2010 15:05
emeadaxsupport: Error when deploying AX Report to SQL Reporting Server - Client found response type of 'text/html;charset=utf8;' but expected 'text/html' Blog bot DAX Blogs 0 12.01.2010 04:44
emeadaxsupport: You get the following warning message in BizTalk Server 2006 R2/2009 - The message does not contain a body part Blog bot DAX Blogs 0 18.09.2009 03:13
Часовой пояс GMT +3, время: 00:32.
