#1 |
Dianne Siebold: Default Location when Saving Attachments in Outlook 2010
Источник: http://blogs.msdn.com/b/dsiebold/arc...look-2010.aspx
============== If you're an Outlook 2010 user, you've probably noticed that when you save an attachment, it brings up some default file location. Then you have to click through to navigate to the folder where you like to save your files. This was really getting me down and I figured it was one of those small issues that had a solution, so today I finally decided to investigate. What I found is this KB article entitled How to change the folder where e-mail messages and attachments are saved in Outlook 2003 and in Outlook 2007. The article explains how to add a registry entry so that when you save an attachment, the Save Attachment dialog opens to the default location that you specify. In spite of the title, the process does work with Outlook 2010. This tip could save you a few seconds each time you save an attachment. I feel my productivity soaring already. Источник: http://blogs.msdn.com/b/dsiebold/arc...look-2010.aspx
Опции просмотра | |
