Старый 07.09.2012, 14:11   #1
25,643 / 848 (80) +++++++
sashanazarov: How one new table relation may break your code somewhere
Источник: http://sashanazarov.blogspot.com/201...may-break.html
Yesterday I spent some time figuring out why intercompany functionality on my box stopped working after upgrade to CU3. No errors were thrown - it just didn't create IC chains, although the setup was correct. There were no recent changes in the TFS history that would help understand why that happened.
Whyle debugging, I found that the quiry used to fetch sales lines was broken in some method. In the standard, it linked SalesLine and InventTable by using QueryBuildDataSource.relations() method, passing true as a parameter. In the customized version of SalesLine, another relation to InventTable was added, linking a new SalesLine field with InventTable.ItemId field. So, the relations method desided that this is the new relation that should be used when building a query for IC chain creation.
It was not an issue before the upgrade, as the old relation was still selected properly. But somehow the upgrade updated IDs or whatever that determined in which priority the relations should be used by relations method.
So, beware of that effect next time you add a table relation.
Dynamics Mobile: How to code your own barcode enabled tasklets (Motorola and Intermec devices) Blog bot DAX Blogs 1 03.06.2014 06:34
How to make a temporary instance of a database table to be shown on the form Blog bot DAX Blogs 0 02.03.2012 01:18
Paint it black: How to color rows in Table form control Blog bot DAX Blogs 0 12.07.2011 02:11
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 05:44.
