Старый 05.02.2013, 07:12   #1
25,626 / 848 (80) +++++++
crminthefield: The plug-in execution failed because no Sandbox Hosts are currently available.
Источник: http://blogs.msdn.com/b/crminthefiel...available.aspx
You have successfully implemented CRM servers and expect your Sandbox service to execute plugins in Isolation mode; however, they fail with an error:
ERROR:
The plug-in execution failed because no Sandbox Hosts are currently available. Please check that you have a Sandbox server configured and that it is running.
System.ServiceModel.EndpointNotFoundException: Microsoft Dynamics CRM has experienced an error. Reference number for administrators or support: #357E9BEE
Possible Cause:
1. CRM Sandbox service is not running
2. CRM Sandbox ports are unavailable
3. CRM Sandbox service is missing SPN's
4. CRM Sandbox is load balanced and Hosts cannot be reached
Potential Solution:
1. Ensure Sandbox services are running on each Full CRM 2011 Server.
2. Ensure you have TCP port 808 listed on your CRM Front end server IIS website.
(Either on Default website or the Microsoft Dynamics Website)
Example:
Ref for more port information: http://technet.microsoft.com/en-us/l.../hh699823.aspx
3. Check if you have the required SPN’s register against the Domain account used to run the Sandbox account.
NOTE: It is best practice to have least privileged account run the Sandbox service.
Example:
MSCRMsandboxservice/WebServerName
MSCRMsandboxservice/WebServerName.Domain.com
Ref CRM 2011 security consideration article: http://technet.microsoft.com/en-us/library/hh699825
Ref- Easy generation of SPN’s for CRM 2011
4. If this is a Load Balanced Sandbox server then you may want to add the following registry key to the servers that run as Sandbox hosts.
Key Name: sandboxforcemultiplebox
Type: DWord (32Bit)
Value: 1
Warning Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk.
NOTE: Step 4 is applicable only if you have multiple full CRM 2011 servers or multiple Sandbox hosts load balanced in an environment.
If the issue is not still not resolved please open a support case with Microsoft for additional support.
Kaustubh Giri
Microsoft Premier Field Engineer
Microsoft Dynamics CRM Team Blog: Finding Which Message Requests Support the Execution of Plug-ins in CRM 2011 and CRM Online Blog bot Dynamics CRM: Blogs 0 16.10.2012 07:12
crminthefield: Error Message “There is no such object on the server.” when using Microsoft Dynamics CRM rule deployment wizard with Exchange 2010 Blog bot Dynamics CRM: Blogs 0 25.05.2012 21:12
crminthefield: Viewing Detailed Errors for Failed Worflows in CRM Blog bot Dynamics CRM: Blogs 0 19.05.2012 00:11
crminthefield: How to Re-Send Failed CRM E-mails in bulk Blog bot Dynamics CRM: Blogs 0 06.12.2011 06:12
emeadaxsupport: Query execution failed for data set 'Company' Blog bot DAX Blogs 0 28.10.2009 00:06
Часовой пояс GMT +3, время: 00:20.
