Старый 11.04.2017, 01:31   #1
25,643 / 848 (80) +++++++
organicax: D365 applying application hotfix
Источник: https://organicax.com/2017/04/10/d36...cation-hotfix/
In a previous post we had a look at applying an binary hotfix to D365. At some point you will likely also need to apply application updates. The process has a few month steps in it compared to the binary updates because you may have customization or ISV solutions you will need to reconcile and test with.
As well in a production environment you will likely take the hotfix into your source control and produce a application build for testing before deploying. In this example I’ll skip the source control and just deploy a simple hotfix to go through the basic process. This is fine if you are using the demo VM’s and want to be able to try out a application hotfix in one of those environments.
Here is a quick overview.
D365
Cheers
Lachlan
Filed under: Lifecycle Services
emeadaxsupport: Warning when installing AX 2012 R3 Application hotfix: The model store you selected requires a newer version of the installer than the one you're using. Blog bot DAX Blogs 0 03.09.2015 15:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics 5.0 Service Pack 1 Blog bot Dynamics CRM: Blogs 0 04.06.2010 12:51
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics 4.0 Service Pack 3 Blog bot Dynamics CRM: Blogs 0 04.06.2010 12:28
Права на добавление объектов в Дизайнере Cyr NAV: Администрирование 10 13.06.2009 21:27
Часовой пояс GMT +3, время: 11:41.
