#1 |
Problem with inherited RunBase class
Hi,
First I apopogize for my english. The my problem is: I have class "Class1"inheritor of RunBase.In this class I have overrided dialog(), getFromDialog() and Init() methods.I have other class "Class2"who inherited mentioned above Class1.In second class I have overrided pack() and unpack() methods.When I have two instantions of "Class2" I do not close first instantion while second is opened. How I resolve this problem? Thank's you in advance. Class1: X++: class Class1 extends RunBase { NoYes checkThing; DialogField dialogCheckThing; } protected Object dialog() { DialogRunBase dialog; ; dialog = super(); dialogCheckThing = dialog.addFieldValue(typeid(NoYes), checkThing); return dialog; } public boolean getFromDialog() { boolean ret; ret = super(); checkThing = dialogCheckThing.value(); return ret; } X++: class Class2 extends Class1 { #define.CurrentVersion(1) #localmacro.CurrentList checkThing #endmacro } public container pack() { return [#CurrentVersion, #CurrentList]; } public boolean unpack(container packedClass) { boolean _ret = false; Integer _version = conPeek(packedClass,1); switch (_version) { case #CurrentVersion: [_version, #CurrentList] = packedClass; _ret = true; break; } return _ret; } public void run() { super(); this.prompt(); } public static void main(Args args) { Class2 class2 = new Class2(); ; if(class2.init()) { class2.run(); } } Последний раз редактировалось ist; 14.11.2007 в 14:49. |
#2 |
Could you please explain your problem once again? It's not quite clear.
Not registered yet? Register here! Have comments, questions, suggestions or anything else regarding our web site? Don't hesitate, send them to me |
#3 |
MVP
you must also define the macro in class1 + pack + unpack
look at the next link for more details http://axstart.spaces.live.com/blog/...C0A0!292.entry |
| Теги |
| runbase |
