#1 |
palleagermark: Document management on Return Order may apply documents to wrong record
Источник: http://palleagermark.blogspot.com/20...order-may.html
============== The following bug applies to AX 2009 application build number 5.0.1500.809 and earlier. When you attach a document or note through document management to a return order line, the document or note might be attached to the current inventory dimension record rather than the return order line. Repro steps:
| Теги |
| ax2009 |
