Старый 06.05.2011, 02:19   #1
25,643 / 848 (80) +++++++
sumitsaxfactor: AOSAuthorization property on tables
Источник: http://sumitsaxfactor.wordpress.com/...rty-on-tables/
This property is part of Tables Permission Framework (TPF). The Table Permissions Framework (TPF) enables administrators to add an additional level of security to tables that store sensitive data. TPF adds table-level security that verifies access rights no matter the origin of the request.
To enable TPF, an administrator specifies a value for the AOSAuthorizationProperty on a specific table in the AOT. The AOSAuthorizationProperty authorizes Create, Read, Update, and Delete operations. For some tables, it is important to authorize all operations because the data is sensitive. For other tables, you might find it suitable to specify a subset of operations, such as Create, Update, and Delete. In the case when you have specified a subset, the AOS authorizes the Create, Update, and Delete operations, but allows users to perform View operations if they have access to Microsoft Dynamics AX.
TPF can be enabled on any table in the Microsoft Dynamics AX database. For the sake of time and efficiency, however, administrators assign TPF to tables that are considered to be sensitive or to be of critical business value.
For example, consider the following scenario:
  1. Microsoft Dynamics AX and allows users to access data by using the Microsoft Dynamics AX client, Enterprise Portal, the Application Integration Framework, and a third-party application that connects to Microsoft Dynamics AX by using the .NET Business Connector.
  2. The administrator configured a Microsoft Dynamics AX user group called Senior Accountants, and members of this group have access to sensitive data about financial information and trade secrets. One of the database tables that stores this sensitive information is called FinancialResults. This table was added as part of a customization done by a partner after Microsoft Dynamics AX was installed.
  3. In the Application Object Tree (AOT), the administrator configures the FinancialResults table so that the Application Object Server (AOS) must authorize all operations for that table. The administrator specifies the value CreateReadUpdateDelete for the AOSAuthorizationProperty.
  4. Soon thereafter, a malicious user discovers a vulnerability in Contoso’s third-party application that connects to Microsoft Dynamics AX by using the .NET Business Connector. The malicious user connects to the database as a member of the CRM_users group and attempts to read the data in the FinancialResults table.
  5. Before allowing the read operation, the AOS checks to see if the user is a member of the Senior Leadership user group and if members of the group have permission to read the data. The malicious user is not a member of the Senior Leadership group, so the AOS denies the read operation.
You can change or add TPF for a table, but its is recommended that you perform TPF changes in a test environment so that you can study the impact of TPF changes on user groups that access that table.
To enable TPF on database table:
  1. In the AOT, expand Data Dictionary > Tables.
  2. Right-click a table, and then click Properties.
  3. Click AOSAuthorizationProperty and select a new value by using the drop-down list.
  4. Click Save All.
If you added TPF to a table, you might need to specify or expand permissions for user groups that access that table. You can view which objects access a table by using the Used-by command in the AOT:
  2. Right-click a table, and then click Add-ins > Cross-reference > Update.
  3. Right-click a table, and then click Add-ins > Cross-reference > Used by. The Used by form is displayed. This form shows all objects that access the selected table and what permissions (the Reference column) are required when accessing the table. You might need to adjust user group permissions if you set tighter restrictions on a table.
Проблема: Массовое развертывание клиентов Dynamics Ax 2009 Poleax DAX: Администрирование 8 23.08.2012 17:28
axdaily: SQL temporary tables in AX 2012 Blog bot DAX Blogs 25 06.05.2011 10:18
Prabhats: DAX 2009: Temporary Tables in Enterprise Portal Blog bot DAX Blogs 0 27.04.2011 11:11
Проблема с установкои Email Router на CRM 4 Kosta100 Dynamics CRM: Администрирование 1 22.02.2009 14:00
Ruslan Goncharov: Mandatory property for DialogField Blog bot DAX Blogs 1 29.12.2007 20:48
Часовой пояс GMT +3, время: 10:10.
