Старый 20.03.2013, 01:11   #1
25,554 / 848 (80) +++++++
bojensen: Simple SSRS report example by using Ax-Query and Ranges
Источник: http://blogs.bojensen.eu/?p=4678
In this report I am going to use the Ax-Query in the SSRS business logic and report will be generated by using SSRS Business logic. For this report… 1) Define the sample Ax Query in Dynamics Ax as follows… 2) In the above SampleCustomers query I had defined the ranges for the Name Field. 3) [...]
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
ax-erp: X++ Code to get the Ranges / Criteria from Query Blog bot DAX Blogs 0 12.06.2012 12:11
jinx: Dynamics AX – Query-Ranges und Filtereinstellungen des Benutzers Blog bot DAX auf Deutsch 0 04.02.2010 00:05
paruvella: Dynamics Ax - Simple SSRS report example by using Ax-Query and Ranges Blog bot DAX Blogs 0 08.01.2010 16:05
Проблема при создании нового Query в Report (AX 2009) Galyna DAX: Программирование 1 21.12.2009 01:56
Часовой пояс GMT +3, время: 03:19.
