Старый 28.06.2014, 00:13   #1
25,644 / 848 (80) +++++++
dynamicscpm: Improvements made to User Integration for Microsoft Dynamics AX 2012 for deleted or removed users
Источник: http://blogs.msdn.com/b/dynamics_fin...ved-users.aspx
We've been hearing feedback that the user integration for Microsoft Dynamics AX 2012 wasn't handling deleted or removed users as well as it could. With CU9 we've made a few improvements to make sure that a user within Dynamics AX who is deleted from your Active Directory will no longer have access to Management Reporter, and other users will continue working as-is. You can learn more about the user integration here. The following changes were made, and are available today with CU9.
  • Deleting a user from Active Directory will now just cause that user to be removed from Management Reporter.
  • The integration log now will provide a message providing the user or users that were removed because they do not exist in Active Directory.
  • Not entering the Management Reporter license into Report Designer will no longer cause the initial integration to remain in an incomplete status. Instead it will only integrate four users for the demo license. You will want to make sure that the license is entered in Report Designer under Tools | Registration for the rest of your users to integrate.
We would still recommend removing that user from within Dynamics AX, but not doing so immediately will not cause any negative side effects for Management Reporter. Thank you to all those who submitted feedback in this area.
Старый 28.06.2014, 20:03   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Источник: blogs.msdn.com/b/dynamics_financial_reporting/archive/2014/06/27/improvements-made-to-user-integration-for-microsoft-dynamics-ax-2012-for-deleted-or-removed-users.aspx
Это значит, что вышел AX 2012 R2 CU9 или что?
Старый 28.06.2014, 22:49   #3
Хмм. еще даже CU8 нету, а они уже что-то про CU9 пишут.. хз
Старый 29.06.2014, 00:14   #4
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
это про Management Reporter
Хотя, мне не понятен кипеж: удаленный пользователь из AD, он же залогиниться не сможет, какой доступ в Management Reporter?
Или это такая поделка, которая копирует себе пользователей и дает им доступ без обращения к AD?
(Кто-то видел живое использование Management Reporter?)
Solutions Monkey: Microsoft Dynamics AX 2012 EP user interface enhancements Blog bot DAX Blogs 0 13.09.2011 10:11
mfp: Microsoft Dynamics AX 2012 is here! Blog bot DAX Blogs 10 04.08.2011 17:11
Часовой пояс GMT +3, время: 08:13.
