		#1 |
			I am pleased to announce the release of the SQL Server Database Compression Analyzer for Dynamics. This tool was created to help Dynamics partners and customers leverage the benefits of SQL Server Data Compression and to make the processing of analyzing and implementing compression quicker and easier. I know there are several generic “Compression Tools” available on the web and I am sure they are all fine, but none of these tools take into account the design eccentricities of the Dynamics database, causing many of these tools to error out or not run at all and none of them have been extensively tested on all of the Dynamics products. The Dynamics Compression Analyzer was written to handle these eccentricities and has been extensively tested on all of the Dynamics Products; AX, NAV, CRM, GP, and SL. This tool will walk you through analyzing your index usage helping you make the decision of which indexes to compress and which indexes not to compress and what level of compression ROW or PAGE to use. Once you have analyzed the data and decided what to compress and how to compress, the tool will do the actual compression for you and let you know how much space you’ve have reclaimed.
			You can get the Microsoft SQL Server Data Compression Tool for Dynamics here: http://archive.msdn.microsoft.com/MSSDCTD Some of the Benefits of SQL Server Database Compression:
 Michael De Voe Senior Premier Field Engineer Microsoft Dynamics Microsoft Certified Master - SQL Server 2008 Источник: http://feedproxy.google.com/~r/Micro...-dynamics.aspx
	Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору.  |
