Старый 18.08.2017, 00:12   #1
25,644 / 848 (80) +++++++
palleagermark: Package problem with LCS Code Upgrade to July 2017 release
Источник: http://www.agermark.com/2017/08/pack...e-upgrade.html
If you get an error like "There is a problem with package 'ContactPerson'. Either the source version being upgraded from is incorrectly identified, or the target version has a package with the same name as a custom package." and you don't have a custom package of the same name, the solution could be the following.
In your existing source (Main branch) you should remove dependencies to the failing models from you model definitions. Check in the change and start the upgrade tool again.
When the upgrade tool is finished you should roll back your change in Main, to keep that branch working.
dynamicsaxse: July 2017 release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 25.07.2017 20:11
palleagermark: New "Retail" model in "July 2017" creating backwards compatibility issues Blog bot DAX Blogs 5 13.07.2017 12:53
goshoom: Custom rules for Code Upgrade Tool Blog bot DAX Blogs 0 15.12.2014 02:11
Microsoft Dynamics CRM Team Blog: Check your JavaScript code to prepare for your upgrade Blog bot Dynamics CRM: Blogs 0 24.08.2013 04:19
Часовой пояс GMT +3, время: 20:17.
