Старый 20.08.2018, 20:13   #1
25,643 / 848 (80) +++++++
erconsult: Overwrite a read-only configuration in D365FO
Источник: http://erconsult.eu/blog/overwrite-a...ion-in-d365fo/
Updating an arbitrary read-only field in a configuration table in may pose a challenge in Dynamics 365 for Finance and Operations, especially in the production environment.
Many options may only be set once, for example the Use warehouse management processes mode of a warehouse, or the Revenue recognition accounting rule in a project group. However, the data export / import entities both in D365FO and AX2012 may bypass the AOS validation and break the database consistency as long as a data entity exists.
Here is how: open the Data management workspace and create an Export data project. Pick the respective data and reduce the number of exported fields in the mapping to the minimum: the entity key and the read-only parameter in question.
Drill down into the Entity structure and turn off the Run business validations checkbox:
Then use the Modify target mapping button to clear the Call validate Field method checkbox from the entity attribute in question:
Export the data, download the ZIP data package, extract the Excel file and amend the parameter in the file as desired. Then re-pack the ZIP data package with the updated file (replace the original), create an Import data project, upload and import the package. With a high probability the Data management engine is going to bypass any application logic and update the existing record without further asking.
As a matter of fact, this method is even more brutal than the table browser (RIP, dear table browser, you are truly missed), since it ignores field properties set at the table metadata level.
The post Overwrite a read-only configuration in D365FO appeared first on ER-Consult.
Старый 21.08.2018, 16:24   #2
trud is offline
trud
1,039 / 1633 (57) ++++++++
О, сейчас и это запретят
Хотя конечно не каждый справится с датаимпортом, это посложнее чем браузер таблиц
erconsult: Copy-paste with keyboard script 2: from Excel to D365FO Blog bot DAX Blogs 0 03.08.2018 11:12
erconsult: Minimalistic EU VAT Configuration in Dynamics AX Blog bot DAX Blogs 0 18.03.2017 02:20
Microsoft Dynamics CRM Team Blog: Read-optimized forms Blog bot Dynamics CRM: Blogs 0 23.03.2012 04:25
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 01:04.
