Старый 25.10.2007, 15:20   #1
25,751 / 851 (80) +++++++
axaptapedia: Adding only one Dimension in Dialog
Источник: http://www.axaptapedia.com/Adding_on...sion_in_Dialog
Summary: New page: To add new field in dialog we use '''addField()''' method. When we try to add for example Dimension field Axapta adds all the fields automatically. But sometimes we need to add only one pa...
<div>To add new field in dialog we use '''addField()''' method. When we try to add for example Dimension field Axapta adds all the fields automatically.
But sometimes we need to add only one particular field.
=== Idea ===
To solve this problem we just need to pass array index as parameter.
=== Solution ===
1. Add into Dialog class '''addField()''' method another one parameter:
DialogField addField(
int type,
FieldLabel label = '',
FieldHelp help = '',
ArrayIdx idx = 0 //GRR modified for ArrayFields
DialogField DialogField;
fields += 1;
DialogField = new DialogField(this,type,fields);
this.addCtrlDialogField(dialogField.name());
// dialogField.init(this); //standard
dialogField.init(this, idx);//GRR modified for ArrayFields
if (label)
dialogField.label(label);
if (help)
dialogField.helpText(help);
this.addDialogClass(dialogField);
return dialogField;
2. Add into DialogField class '''init()''' before while (f
if((idx)&&(idx
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 04.04.2009 22:05
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 31.03.2009 06:06
axaptapedia: RunBaseReport Blog bot DAX Blogs 0 03.08.2008 20:10
dynamicsmatters: Adding a storage Dimension (Inventory Status) Blog bot DAX Blogs 0 29.05.2008 04:12
Kashperuk Ivan: 3 Dialog extensions Blog bot DAX Blogs 4 28.09.2007 18:56
Часовой пояс GMT +3, время: 14:09.
