Старый 18.12.2007, 19:50   #1
25,751 / 851 (80) +++++++
Arijit Basu: Multiple AOS in a Multi CPU Machine :)
Источник: http://daxguy.blogspot.com/2007/12/m...u-machine.html
You are all aware that presently AX AOS does not support more that 2 processors. Now say you have a multi processor Box where you want to install multiple AOS and make sure that each AOS Service points to a specific processor. Follow the steps:
1.Open Task Manager
2.Right Click on AX32Serv.exe
3.Click "Set Affinity"
4.A window opens up which shows all the CPU's your Box has
5.You can now , for each AOS Service point/ check the CPU's you want to run on :)
But the limitation is that when you restart the service/ Box , you must do this again. Also if the AOS Service runs under local/system/network Account, you cannot do this. Only available for AD accounts.
This is NOT recommended in a live environment.
Happy DAX-ing
Arijit Basu: How to Improve Stability of the AOS for Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 1 14.12.2007 15:24
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
Arijit Basu: Post Ledger Transactions via X++ Blog bot DAX Blogs 0 27.07.2007 17:30
Часовой пояс GMT +3, время: 20:31.
