Старый 02.04.2019, 22:11   #1
a33ik: How to identify that code is running under business connector?
Источник: http://daxonline.org/1646-how-to-ide...connector.html
There is X++ code, which will allow you to identify that currently execution is under BC.
SysClientSessions sysClientSessions; select firstOnly RecId from sysClientSessions where sysClientSessions.SessionId == SessionId() && sysClientSessions.clientType == SessionType::BC; if (sysClientSessions) { // business connector }
Navigate Into Success: How do I: Really set up Azure Active Directory based authentication for Business Central APIs Blog bot NAV: Blogs 0 17.02.2019 04:43
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
Часовой пояс GMT +3, время: 13:12.
