Старый 10.10.2007, 17:23   #1
egorych is offline
egorych
Oracle
761 / 154 (7) ++++++
Сообщение от polygris Посмотреть сообщение
egorych куда UDF возвращает? UDF возвратит recordSet если сделать SELECT UDF()
а есть какой-то другой способ вызова UDF ?
Цитата из BOL
Calling User-Defined Functions
When calling a scalar user-defined function, you must supply at least a two-part name:
SELECT *, MyUser.MyScalarFunction()FROM MyTableTable-valued functions can be called by using a one-part name:
SELECT *FROM MyTableFunction()However, when you call SQL Server built-in functions that return a table, you must add the prefix :: to the name of the function:
SELECT * FROM ::fn_helpcollations()
axStart: How to restore an AX 3.0 SQL 2000 backup in sql 2005 Blog bot DAX Blogs 0 12.02.2008 15:10
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 12.04.2007 16:10
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 04:50.
