#1 |
CRM
Проблема при создании мероприятия
Добрый день, коллеги!
Тут возникла какая-то глупая проблема ![]() Пакет отправляемый системой на сервер Код: <?xml version="1.0" encoding="utf-8" ?> <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <soap:Body> <Book xmlns="http://schemas.microsoft.com/crm/2006/WebServices"> <content> <appointment> <subject>fdfg</subject> <requiredattendees> <activityparty> <partyid name="Мелешихин, Алексей" type="8">{CBB98654-35D1-DA11-AAA6-00306E1F0D5D}</partyid> </activityparty> </requiredattendees> <regardingobjectid type="4402">{46DF4FFD-A707-DD11-AA3C-00306E1F0D5D}</regardingobjectid> <statuscode>5</statuscode> <scheduledstart>2008-07-09T18:00:00</scheduledstart> <scheduleddurationminutes>30</scheduleddurationminutes> <scheduledend>2008-07-09T18:30:00</scheduledend> <isalldayevent>0</isalldayevent> <ownerid type="8">{F8A1C9D8-B3EC-DA11-B5AB-00306E1F0D5D}</ownerid> <organizer> <activityparty> <partyid name="Евсеев, Александр" type="8">{F8A1C9D8-B3EC-DA11-B5AB-00306E1F0D5D}</partyid> </activityparty> </organizer> </appointment> </content> <typeCode>4201</typeCode> </Book> </soap:Body> </soap:Envelope> Код: <?xml version="1.0" encoding="utf-8"?> <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <soap:Body> <soap:Fault> <faultcode>soap:Server</faultcode> <faultstring> System.Web.Services.Protocols.SoapException: Server was unable to process request. at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at Microsoft.Crm.Platform.Proxy.AppointmentWebService.Book(Appointment appointment) at Microsoft.Crm.Application.SMWrappers.Appointment.Book() at Microsoft.Crm.Application.Platform.Appointment.Book(String activityXml) at Microsoft.Crm.Application.WebServices.ActivitiesWebService.Book(XmlNode content, Int32 typeCode) --> Server was unable to process request. </faultstring> <faultactor>http://crm/AppWebServices/ActivitiesWebService.asmx</faultactor> <error xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <code>0x80044150</code> <displaytitle>Ошибка сервера SQL Server</displaytitle> <displaytext>Ошибка сервера SQL Server. Для получения дополнительных сведений обратитесь к системному администратору.</displaytext> <description>Generic SQL error.</description> <file>Not available</file> <line>Not available</line> <details>Not available</details> <requesturl>http://crm/AppWebServices/ActivitiesWebService.asmx</requesturl> <type>Platform</type> <source>SOAP</source> <stacktrace> at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at Microsoft.Crm.Platform.Proxy.AppointmentWebService.Book(Appointment appointment) at Microsoft.Crm.Application.SMWrappers.Appointment.Book() at Microsoft.Crm.Application.Platform.Appointment.Book(String activityXml) at Microsoft.Crm.Application.WebServices.ActivitiesWebService.Book(XmlNode content, Int32 typeCode) </stacktrace> </error> </soap:Fault> </soap:Body> </soap:Envelope> ![]() MS CRM 3.0 Update Rollup 3 Спасибо. PS Пеняю на сиквел.
MS CRM 3.0/4.0 ![]() Sharepoint 2003, MOSS 2007/2010 ![]() |
#2 |
У меня аналогичная проблема. Есть 1 пользователь, которого нельзя добавить во встречу. Если добавляем, получаем ошибку – Outlook: не удается создать субъект действия с указанным типом объекта. Да же не знаю что и думать?
#3 |
решили проблему - пользователя е-мейл использовался в очереди
Опции просмотра | |
