Старый 08.05.2009, 12:17   #21
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Lightbulb
Подчистил код плагина. Попробуйте это:
using System;
using System.Collections.Generic;
using Microsoft.Win32;
using Microsoft.Crm.Sdk.Query;
// Microsoft Dynamics CRM namespaces
using Microsoft.Crm.Sdk;
using Microsoft.Crm.SdkTypeProxy;
using Microsoft.Crm.SdkTypeProxy.Metadata;
using System.Text;
namespace Crm.Plugins
    public class MyPlugin : IPlugin
        private string _secureInformation;
        private string _unsecureInformation;
        public MyPlugin(string unsecureInfo, string secureInfo)
            _secureInformation = secureInfo;
            _unsecureInformation = unsecureInfo;
        public void Execute(IPluginExecutionContext context)
            DynamicEntity entity = null;
            if (context.InputParameters.Properties.Contains(ParameterName.Target) && context.InputParameters.Properties[ParameterName.Target] is DynamicEntity)
                entity = (DynamicEntity)context.InputParameters.Properties[ParameterName.Target];
            else
                return;
            try
                ICrmService crmService = context.CreateCrmService(true);
                decimal sum = ((CrmMoney)entity.Properties["new_esum"]).Value;
                String new_productname = "";
                if (entity.Properties.Contains("productid"))
                    ColumnSet cs = new ColumnSet();
                    Lookup regarding = (Lookup)entity.Properties["productid"];
                    cs.Attributes.Add("name");
                    product _product = (product)crmService.Retrieve(EntityName.product.ToString(), regarding.Value, cs);
                    if (_product == null || _product.name == null)
                        return;
                    else
                        new_productname = _product.name;
                QueryByAttribute query = new QueryByAttribute();
                query.ColumnSet = new AllColumns();
                query.EntityName = EntityName.productpricelevel.ToString();
                query.Attributes = new string[] { "productidname" };
                query.Values = new string[] { new_productname };
                BusinessEntityCollection retrieved = crmService.RetrieveMultiple(query);
                foreach (DynamicEntity product in retrieved.BusinessEntities)
                    product["amount"] = new CrmDecimal(sum);
                    crmService.Update(product);
            catch (System.Web.Services.Protocols.SoapException ex)
                throw new InvalidPluginExecutionException(String.Format("An error occurred in the {0} plug-in.", this.GetType().ToString()), ex);
Старый 08.05.2009, 12:27   #22
Elka is offline
Elka
Аватар для Elka
431 / 22 (1) +++
Спасибо!!
Пока не изменилось ничего..
"для отладки - необходимо атачиться к w3p процессу." А это как? (стыдно, но правда не знаю.. )
Старый 08.05.2009, 12:38   #23
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Lightbulb
Сообщение от Elka Посмотреть сообщение
Спасибо!!
Для того, чтобы плагин дебажить его сначала надо зарегистрировать.
Что говорит плагин регистратор при попытке регистрации?
Последний раз редактировалось a33ik; 08.05.2009 в 12:50.
Старый 08.05.2009, 13:05   #24
Elka is offline
Elka
Аватар для Elka
431 / 22 (1) +++
В Plagin Registration Tool нажимаю Register -> Register New Assembly
Когда выбираю файл EditPriceList.dll (я его из папки Debug беру..в Release он тоже есть и еще там лежит файл key.snk.. Так и надо? )
Выскакивает ошибка "Unable to load PLugin Assembly" и текст
Unhandled Exception: System.Runtime.Serialization.SerializationException: Тип "PluginRegistrationTool.CrmOrganization" в сборке "PluginRegistration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null" не помечен как сериализуемый.
Server stack trace:
в System.Runtime.Serialization.FormatterServices.InternalGetSerializableMembers(RuntimeType type)
в System.Runtime.Serialization.FormatterServices.GetSerializableMembers(Type type, StreamingContext context)
в System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.InitMemberInfo()
в System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.InitSerialize(Type objectType, ISurrogateSelector surrogateSelector, StreamingContext context, SerObjectInfoInit serObjectInfoInit, IFormatterConverter converter)
в System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.Serialize(Type objectType, ISurrogateSelector surrogateSelector, StreamingContext context, SerObjectInfoInit serObjectInfoInit, IFormatterConverter converter)
в System.Runtime.Serialization.Formatters.Binary.ObjectWriter.Write(WriteObjectInfo objectInfo, NameInfo memberNameInfo, NameInfo typeNameInfo)
в System.Runtime.Serialization.Formatters.Binary.ObjectWriter.Serialize(Object graph, Header[] inHeaders, __BinaryWriter serWriter, Boolean fCheck)
в System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Serialize(Stream serializationStream, Object graph, Header[] headers, Boolean fCheck)
в System.Runtime.Remoting.Channels.CrossAppDomainSerializer.SerializeMessageParts(ArrayList argsToSerialize)
в System.Runtime.Remoting.Messaging.SmuggledMethodReturnMessage..ctor(IMethodReturnMessage mrm)
в System.Runtime.Remoting.Messaging.SmuggledMethodReturnMessage.SmuggleIfPossible(IMessage msg)
в System.Runtime.Remoting.Channels.CrossAppDomainSink.DoDispatch(Byte[] reqStmBuff, SmuggledMethodCallMessage smuggledMcm, SmuggledMethodReturnMessage& smuggledMrm)
в System.Runtime.Remoting.Channels.CrossAppDomainSink.DoTransitionDispatchCallback(Object[] args)
Exception rethrown at [0]:
в System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
в System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
в PluginRegistrationTool.AssemblyReader.RetrievePluginsFromAssembly(String path)
в PluginRegistrationTool.RegistrationHelper.RetrievePluginsFromAssembly(String pathToAssembly)
в PluginRegistrationTool.PluginRegistrationForm.btnLoadAssembly_Click(Object sender, EventArgs e)
Старый 08.05.2009, 13:15   #25
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Очень странно. За годичную практику такого не было у меня.
Ещё такой вопрос. Под каким фреймворком собираете плагин? Нужно под 2.0.
Гугл на вопрос по такой ошибке мне ничего не сказал...
Старый 08.05.2009, 13:41   #26
Elka is offline
Elka
Аватар для Elka
431 / 22 (1) +++
Я не знаю что значит "Под каким фреймворком собираете плагин". Но на моем компе , где я пытаюсь соорудить plugin , установлены
Microsoft .NET Compact Framework 1.0 Developer
Microsoft .NET Compact Framework 2.0
Microsoft .NET Framework 3.5 SP1
А это не может быть из-за того что я работаю в Microsoft Visual C# 2008 Express Edition?
Старый 08.05.2009, 13:46   #27
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
При создании плагина - необходимо выбрать версию фреймворка под который он будет писаться. Посмотрите скриншот (должен быть 2.0).
Миниатюры
За это сообщение автора поблагодарили: Elka (1).
Старый 08.05.2009, 13:59   #28
Elka is offline
Elka
Аватар для Elka
431 / 22 (1) +++
Создать проект.docx
Ой, спасибо большое.. У меня вообще нет возможности выбора фреймворка. Наверно из-за этого все беды...Попробую найти и установить нормальную Visual Studio
Старый 12.05.2009, 17:39   #29
Elka is offline
Elka
Аватар для Elka
431 / 22 (1) +++
Добрый день! После регистрации плагина, создаю в crm продукт для возможной сделки. При сохранении возникает ошибка :"Unable to cast object of type 'Microsoft.Crm.SdkTypeProxy.productpricelevel' to type 'Microsoft.Crm.Sdk.DynamicEntity'".
В плагине так:
Не знаю как исправить .. Помогите, пожалуйста..
Старый 12.05.2009, 17:44   #30
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
В плагине так:
Каст - немного другое. Код плагина выкладывайте - плдскажу, где проблема.
Старый 12.05.2009, 17:47   #31
Elka is offline
Elka
Аватар для Elka
431 / 22 (1) +++
Спасибо Вам большое !!
Вот код:
using
System;
using System.Text;
publicclassMyPlugin : IPlugin
privatestring _secureInformation;
privatestring _unsecureInformation;
publicvoid Execute(IPluginExecutionContext context)
if (context.InputParameters.Properties.Contains(ParameterName.Target) && context.InputParameters.Properties[ParameterName.Target] isDynamicEntity)
entity = (
else
return;
try
ColumnSet cs = newColumnSet();
cs.Attributes.Add(
"name");
return;
else
QueryByAttribute query = newQueryByAttribute();
query.ColumnSet =
newAllColumns();
query.EntityName =
query.Attributes =
newstring[] { "productidname" };
query.Values =
newstring[] { new_productname };
product[
"amount"] = newCrmDecimal(sum);
thrownewInvalidPluginExecutionException(String.Format("An error occurred in the {0} plug-in.", this.GetType().ToString()), ex);
Старый 12.05.2009, 17:55   #32
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Lightbulb
Исправьте код
product["amount"] = newCrmDecimal(sum);
на
foreach (productpricelevel product in retrieved.BusinessEntities)
product.amount = new CrmDecimal(sum);
Старый 12.05.2009, 18:05   #33
Elka is offline
Elka
Аватар для Elka
431 / 22 (1) +++
Ругается на
new CrmDecimal(sum)
"cannot implicity convert type 'Microsoft.Crm.Sdk.CrmDecimal' to 'Microsoft.Crm.Sdk.CrmMoney"
Старый 12.05.2009, 18:07   #34
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Lightbulb
Ругается на
new CrmDecimal(sum)
product.amount = new CrmMoney(sum);
Написано ж что не работает =)
Старый 12.05.2009, 18:48   #35
Elka is offline
Elka
Аватар для Elka
431 / 22 (1) +++
спасибо..
можно еще вопрос..(надеюсь последний..)
Я заново скомпилировала.. В Plugin Registration Tool все отключила (unregister) и заново зарегистрировала плагин.. Однако на сервере s-crm (C:\Program Files\Microsoft Dynamics CRM\Server\bin\assembly) файлы .dll .pdb руками заменить на новые не получается ( их ведь надо заменить?)
А в crm ошибка "Не удалось загрузить сборку подключаемого модуля"
Старый 12.05.2009, 19:01   #36
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Lightbulb
спасибо..
Для подмены файла - из консоли (start - run) запустите команду iisreset.
Старый 12.05.2009, 19:10   #37
Elka is offline
Elka
Аватар для Elka
431 / 22 (1) +++
Ура! Все работает!!! Спасибо большое!!!!!!
Старый 12.05.2009, 22:41   #38
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Вот и славненько.
*чухает голову и думает может в тренеры податься )
Старый 15.05.2009, 14:01   #39
Vuhasty is offline
Vuhasty
Спасибо за детальное об'яснение этой темы.
Все стало значительно понятней, повторил все действия здесь описаные, скопировал код с поста и удалил всьо в методе Execute.
Плугин регистрируется, но выполнятся не хочет пишет немогу загрузить асемблю ...
В ивент вьювере - пусто, можно гдето логи какието найти или продебажить ?
И еще одно - при регистрации прошу положить либу на диск, но не могу найти куда оно ее кладет ...
ЦРМ стоит в папке D:\CRM4 - может здесь собака порылась ?
Последний раз редактировалось Vuhasty; 15.05.2009 в 14:05.
Старый 15.05.2009, 14:12   #40
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Сообщение от Vuhasty Посмотреть сообщение
А Вы сборку застронгнеймили?
c#, plugin, pluginregistrationtool, регистрация
CRM DE LA CREME! Three Top Tips for CRM 4.0 Plugin Development Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
haditeo: Is it possible to register different event handlers in only one assembly to be registered in Dynamics CRM Plugin ? Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
a33ik: Plugin for copying notes and attachements from lead to contact whis is converted from lead for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 10.07.2009 17:05
Ronald Lemmen: Plugin registration tools for Visual Studio 2005 Blog bot Dynamics CRM: Blogs 0 17.04.2009 01:05
PlugIn ImageEntity Konstantin Katsovich Dynamics CRM: Разработка 3 16.01.2009 17:35
Часовой пояс GMT +3, время: 12:05.
