Старый 25.11.2010, 04:12   #1
25,644 / 848 (80) +++++++
axaptapedia: Current Time
Источник: http://www.axaptapedia.com/Current_Time
Summary: Better code examples and improved documentation
=Introduction=
This document lists different ways of getting the current date and/or time on the local machine, AOS server or else where, and then converting it to a utcdatetime data type.
=Dynamics AX versions=
Tested on Dynamics AX 2009 SP1 RU-2
==timeNow Function==
===Client===
Retrieves the current UTC time from the local machinepublic static client utcDateTime timeNowClient()
return DateTimeUtil::newDateTime(
2\\1\\1900,
timeNow(),
DateTimeUtil::getClientMachineTimeZone());
}''Example: 02.01.1900 16:45:02''
===Server===
Retrieves the current UTC time from the AOS serverpublic static server utcDateTime timeNowServer()
2\\1\\1900,
timeNow(),
}''Example: 02.01.1900 16:46:58''
==DateTimeUtil::time Method==
===Client===
Retrieves the current time from the local machine, converts it to an int and then returns it as a utcdatetime data type.public static client utcDateTime timeClient()
02\\01\\1900,
DateTimeUtil::time(DateTimeUtil::getSystemDateTime()));
===Server===
Retrieves the current time from the AOS, rather than the local machine, converts it to an int and then returns it as a utcdatetime data type.public static client utcDateTime timeClientServer()
02\\01\\1900,
DateTimeUtil::time(DateTimeUtil::utcNow()));
Retrieves the current time from the AOS, converts it to an int and then returns it as a utcdatetime data type.public static server utcDateTime timeServer()
02\\01\\1900,
DateTimeUtil::time(DateTimeUtil::parse("1900-01-02T"+time2StrHMS(timeNow()))),
==today Function==
===Client===
Retrieves the current date on the local machine.public static client utcDateTime todayClient()
today(),
0,
}''Example: 24.11.2010 00:00:00''
===Server===
Retrieves the current date on the AOS.public static server utcDateTime todayServer()
today(),
0,
==systemDateGet Function==
===Client===
Retrieves the session date if it has been set, otherwise the current date of the local machine, and then converts it to a utcdatetime data type.public static client utcDateTime systemDateGetClient()
systemDateGet(),
0,
===Server===
Retrieves the session date if it has been set, otherwise the current date of the AOS, and then converts it to a utcdatetime data type.public static server utcDateTime systemDateGetServer()
systemDateGet(),
0,
==DateTimeUtil::getSystemDateTime Method==
===Client===
Gets the current UTC date and time on the local machinepublic static client utcDateTime getSystemDateTimeClient()
return DateTimeUtil::getSystemDateTime();
===Server===
Gets the current UTC date and time on the AOSpublic static server utcDateTime getSystemDateTimeServer()
==COMVariant::createFromTime Method==
===Client===
Creates a new COMVariant object, initializes it with the current time on the local machine and returns a utcdatetime data type.public static client utcDateTime createFromTimeClient()
#XppTexts
#define.Format("\%1 \%2")
#define.Date(1)
#define.Time(2)
COMVariant cOMVariant = COMVariant::createFromTime(timeNow());
container dateParts = str2Con(cOMVariant.ToString(), #Space);
System.Globalization.CultureInfo cultureInfo;
System.DateTime dateTime;
cultureInfo = System.Globalization.CultureInfo::get_CurrentCulture();
dateTime = System.DateTime::Parse(
strFmt(#Format,
conPeek(dateParts, #Date),
conPeek(dateParts, #Time)),
cultureInfo,
System.Globalization.DateTimeStyles::NoCurrentDateDefault);
return dateTime.ToUniversalTime();
===Server===
Creates a new COMVariant object, initializes it with the current time on the AOS and returns a utcdatetime data type.public static server utcDateTime createFromTimeServer()
#XppTexts
#define.Date(1)
#define.Time(2)
new InteropPermission(InteropKind::ClrInterop).assert();
strFmt(#Format,
cultureInfo,
return CLRInterop::getAnyTypeForObject(dateTime.ToUniversalTime());
==System.DateTime::get_Now() Method==
===Client===
Gets a DateTime object that is set to the current date and time on the local machine, expressed as the local time, and returns it as a utcdatetime data typepublic static client utcDateTime get_NowClient()
System.DateTime::get_Now().ToUniversalTime());
===Server===
Gets a DateTime object that is set to the current date and time on the AOS, expressed as the local time, and returns it as a utcdatetime data typepublic static server utcDateTime get_NowServer()
==System.DateTime::get_UtcNow Method==
===Client===
Gets a DateTime object that is set to the current date and time on the local machine, and returs it as a utcdatetime data type.public static client utcDateTime get_UtcNowClient()
return System.DateTime::get_UtcNow();
===Server===
Gets a DateTime object that is set to the current date and time on the AOS, and returs it as a utcdatetime data type.public static server utcDateTime get_UtcNowServer()
System.DateTime::get_UtcNow());
==Win32_LocalTimeClient==
===Client===
Gets the current point in time on the local machine as Win32_LocalTime and converts it to a utcdatetime data type.public static client utcDateTime Win32_LocalTimeClient()
COM WMIService;
COM localTime;
COM time;
WMIService = COM::getObjectEx(@'winmgmts:{impersonationLevel=impersonate}!\\.\root\cimv2');
localTime = WMIService.ExecQuery('Select * from Win32_LocalTime');
time = new COMEnum2Object(localTime).getFirst();
return DateTimeUtil::newDateTime(mkdate(time.day(), time.month(), time.year()),
str2Time(strFmt("%1:%2:%3",
strRFix(time.hour(), 2, "0"),
strRFix(time.minute(), 2, "0"),
strRFix(time.second(), 2, "0"))),
===Server===
Gets the current point in time on the AOS as Win32_LocalTime and converts it to a utcdatetime data type.public static server utcDateTime Win32_LocalTimeServer()
COM WMIService;
COM localTime;
COM time;
new InteropPermission(InteropKind::ComInterop).assert();
==GETDATE (Transact-SQL)==
===Server===
Returns the current database system timestamp as a utcdatetime data type without the database time zone offset. This value is derived from the operating system of the computer on which the instance of SQL Server is running.public static server utcDateTime getDateSQLServer()
SysSQLSystemInfo systemInfo = SysSQLSystemInfo::construct();
System.Data.SqlClient.SqlConnectionStringBuilder builder;
System.Data.SqlClient.SqlConnection connect;
System.Data.SqlClient.SqlCommand command;
builder = new System.Data.SqlClient.SqlConnectionStringBuilder();
builder.set_DataSource(systemInfo.getLoginServer());
builder.set_InitialCatalog(systemInfo.getloginDatabase());
builder.set_IntegratedSecurity(true);
command = new System.Data.SqlClient.SqlCommand(
'SELECT GETDATE()',
new System.Data.SqlClient.SqlConnection(builder.ToString()));
connect = command.get_Connection(); connect.Open();
dateTime = command.ExecuteScalar();
command.Dispose();
connect.Dispose();
}''Example: 02.01.1900 16:47:00''
==NIST Internet Time Service==
===Client===
Returns a utcdattime data type set with a time server used by the NIST Internet Time Service (ITS).
public static client utcDateTime remoteTimeServer()
#XppTexts
#define.Format('20\%1T\%2')
#define.Date(2)
#define.Time(3)
#define.Port(13)
System.Net.Sockets.TcpClient tcpClient;
System.Net.Sockets.NetworkStream networkStream;
System.Text.Encoding encoding;
System.Byte[] bytes;
int receiveBufferSize;
container result;
tcpClient = new System.Net.Sockets.TcpClient();
tcpClient.Connect('time-b.nist.gov', #Port);
networkStream = tcpClient.GetStream();
receiveBufferSize = tcpClient.get_ReceiveBufferSize();
bytes = new System.Byte[receiveBufferSize]();
networkStream.Read(bytes, 0, receiveBufferSize);
tcpClient.Close();
encoding = System.Text.Encoding::get_ASCII();
result = str2Con(encoding.GetString(bytes), #Space);
return DateTimeUtil::parse(strFmt(
#Format,
conPeek(result, #Date),
conPeek(result, #Time)));
}''Example: 02.01.1900 16:45:05''
Старый 29.11.2010, 22:11   #2
Summary: Tested on RU-6
=Introduction=
Tested on Dynamics AX 2009 SP1 RU-2, RU-6
===Client===
2\\1\\1900,
timeNow(),
===Server===
2\\1\\1900,
timeNow(),
===Client===
02\\01\\1900,
===Server===
02\\01\\1900,
02\\01\\1900,
==today Function==
===Client===
today(),
0,
===Server===
today(),
0,
===Client===
systemDateGet(),
0,
===Server===
systemDateGet(),
0,
===Client===
===Server===
===Client===
#XppTexts
#define.Date(1)
#define.Time(2)
strFmt(#Format,
cultureInfo,
===Server===
#XppTexts
#define.Date(1)
#define.Time(2)
strFmt(#Format,
cultureInfo,
===Client===
===Server===
===Client===
===Server===
===Client===
COM WMIService;
COM localTime;
COM time;
===Server===
COM WMIService;
COM localTime;
COM time;
===Server===
'SELECT GETDATE()',
command.Dispose();
connect.Dispose();
===Client===
#XppTexts
#define.Date(2)
#define.Time(3)
#define.Port(13)
container result;
tcpClient.Close();
#Format,
axaptapedia: Current Time Blog bot DAX Blogs 0 17.11.2010 04:12
Dynamics AX Sustained Engineering: Date\time data reflected in User's preferred time zone after conversion from UTC Blog bot DAX Blogs 0 10.08.2010 02:07
jinx: Dynamics AX AIF Webservices – Date, Time und Datetime Datentypen Blog bot DAX auf Deutsch 0 12.06.2010 01:05
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 08:22.
