Старый 21.10.2010, 16:08   #1
Why not? is offline
Why not?
? Проблема заведения новых пользователей
Добрый день.
Никто не сталкивался с такой проблемой, CRM 4.0 Rollup 10, завели нового пользователя, выдали права. При заходе пользователя в CRM вылетает ошибка, что недостаточно прав, в логах вот такое сообщение:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 21.10.2010 16:40:00
Event time (UTC): 21.10.2010 12:40:00
Event ID: f03e22cb306948b0b24b6a016a05c535
Event sequence: 305247
Event occurrence: 90
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/ROOT-1-129320488475882203
Trust level: Full
Application Virtual Path: /
Application Path: C:\inetpub\wwwroot\
Machine name: SMSK01CRM01
Process information:
Process ID: 2000
Process name: w3wp.exe
Account name: cmpname\crm
Exception information:
Exception type: TargetInvocationException
Exception message: Exception has been thrown by the target of an invocation.
Request information:
Request URL: https://crm4.bacint.ru:443/bac/default.aspx
Request path: /bac/default.aspx
User host address: 10.101.198.201
User: cmpname\Anton.Ivanov
Is authenticated: True
Authentication Type: Negotiate
Thread account name: cmpname\crm
Thread information:
Thread ID: 3
Thread account name: BACINT\crm
Is impersonating: False
Stack trace: at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Web.Services.Protocols.LogicalMethodInfo.Invoke(Object target, Object[] values)
at Microsoft.Crm.Extensibility.InternalOperationPlugin.Execute(IPluginExecutionContext context)
at Microsoft.Crm.Extensibility.PluginStep.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.Pipeline.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.MessageProcessor.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.InternalMessageDispatcher.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.ExternalMessageDispatcher.Execute(String messageName, Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, PropertyBag fields, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.RequestBase.Process(Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.RequestBase.Process(CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.CrmServiceInternal.Execute(RequestBase request, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.InProcessCrmService.Execute(Object request)
at Microsoft.Crm.Application.Platform.ServiceCommands.PlatformCommand.ExecuteInternal()
at Microsoft.Crm.Application.Platform.ServiceCommands.UpdateCommand.Execute()
at Microsoft.Crm.Application.Controls.AppPage.UpdateUserLanguageIfNecessary()
at Microsoft.Crm.Application.Controls.AppPage.OnInit(EventArgs e)
at System.Web.UI.Control.InitRecursive(Control namingContainer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Все пользователи, которые были заведены до этого нормально заходят в CRM, хотя иногда подобные ошибки для них появляются в логах. При этом с такими же правами другие пользователи также бес проблем заходят.
Заранее спасибо!
Custom event details:
Старый 21.10.2010, 16:19   #2
slivka_83 is offline
slivka_83
Консультант-джедай
Аватар для slivka_83
1,683 / 374 (16) ++++++
1. А локально этот юзвер заходит?
2. Это лог винды, а лог CRM не покажите?
Экстремал и буду экстремать!
Блога
Старый 21.10.2010, 16:20   #3
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Ошибусь, если предположу, что пользователю выдали кастомную роль?
Если я прав - выполните следующее действие:
1. Выдайте пользователю одну из стандартных ролей (не важно какую).
2. Выполните вход в CRM пож этим пользователем.
3. Уберите у пользователя предоставленную в п.1.
Старый 21.10.2010, 16:41   #4
Why not? is offline
Why not?
Thumbs up
Кажется сработало, завтра проверим ещё на паре пользователей. Спасибо!!!
Старый 29.12.2010, 15:53   #5
fatty_bu is offline
fatty_bu
Аватар для fatty_bu
90 / 18 (1) ++
Добрый день!
А иначе никак проблему не решить? А то клиент ругается, что это нехороший системный баг(
Старый 29.12.2010, 15:55   #6
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Сообщение от fatty_bu Посмотреть сообщение
Добрый день!
Можете обратиться на сапорт Microsoft, но, боюсь, что они ответят вам теми же инструкциями, что написал я, но по-английски.
Старый 29.12.2010, 16:11   #7
fatty_bu is offline
fatty_bu
Аватар для fatty_bu
90 / 18 (1) ++
уже писали.
пока по миру походит, мы уже решение найдем)
Старый 29.12.2010, 18:51   #8
Bondonello is offline
Bondonello
Kostya Afendikov
Аватар для Bondonello
510 / 106 (5) +++++
уже писали.
Попробовали установить новый роллап?
Старый 29.12.2010, 19:31   #9
Konstantin Katsovich is offline
Аватар для Konstantin Katsovich
243 / 57 (2) ++++
Если мне не изменяет память, эта проблема существует и в CRM 3.0.
А решения
Читайте SDK!!!
Старый 29.12.2010, 19:54   #10
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Честно говоря ни разу с подобным не сталкивался, но и роли я создавал путем копирования существующих. Существует так же известная проблема с аналогичными симптомами, когда у кастомной роли нет прав на системный объект Представление и, видимо, ряд других. Возможно именно при первом входе для пользователя создаются различные системные записи вроде личных настроек и пр. Попробуйте поставить последний пакет исправлений и пересоздать ваши роли. Или пересоздайте их путем копирования стандартных. Возможно это решит проблему
Старый 30.12.2010, 11:34   #11
fatty_bu is offline
fatty_bu
Аватар для fatty_bu
90 / 18 (1) ++
Попробывал убрать все права из системной роли и дал ее пользователю вместе с кастомной настроенной ролью, после этого такая же проблема. Видимо это все-таки в настройке ролей дело.
Старый 30.12.2010, 14:06   #12
Артем Enot Грунин
Был известный баг: системные роли имеют ряд скрытых привилегий, которые не назначаются при создании кастомной роли. Второй момент: по неизвестным причинам, в настройках роли можно отобрать привилегии без которых вход будет невозможен (чтение настроек, форм и пр.). Фокус был не в том, чтобы убрать все что можно у системной роли и дать ее пользователю вместе с кастомной. Фокус в том, чтобы делать нужные вам роли из наиболее подходящих системных. Нужно отсекать лишнее, а не удалять все.
Старый 11.01.2011, 18:04   #13
IgorF is offline
IgorF
Учаснег
Аватар для IgorF
307 / 37 (2) +++
насколько я помню данный "баг" - нужно чтобы стояла привилегия на запись своих параметров.
Изображения
http://about.me/fedorovigor
За это сообщение автора поблагодарили: fatty_bu (1).
Старый 12.01.2011, 11:55   #14
fatty_bu is offline
fatty_bu
Аватар для fatty_bu
90 / 18 (1) ++
Сообщение от IgorF Посмотреть сообщение
Спасибо, помогло!
Маппинг пользователей при импорте организации migunov Dynamics CRM: Администрирование 2 25.06.2009 12:19
Проблема с заведением пользователей Camena Dynamics CRM: Администрирование 11 30.04.2009 14:38
Проблема при создании мероприятия ShurikEv Dynamics CRM: Функционал 2 03.11.2008 18:26
Добавление пользователей в CRM4 AlexsSDa Dynamics CRM: Администрирование 22 14.07.2008 11:21
Проблема с добавлением пользователей xm-ad Dynamics CRM: Администрирование 5 26.10.2007 15:58
Часовой пояс GMT +3, время: 19:59.
