Старый 14.05.2012, 23:13   #1
25,626 / 848 (80) +++++++
dax-lessons: Get list of printers in Dynamics AX 2012 for SSRS reports [Using X++]
Источник: http://dynamicsaxgyan.wordpress.com/...ports-using-x/
Friends,
Below code snippet will help to get the list of available printers in AX 2012.
static void SR_AvailablePrinters_SSRS(Args _args)
    Microsoft.Dynamics.AX.Framework.Reporting.Shared.PrinterHelper printerHelper;
    System.Collections.ArrayList names;
    System.Collections.IEnumerator enumerator;
    str name;
    // BP Deviation documented
    printerHelper = new Microsoft.Dynamics.AX.Framework.Reporting.Shared.PrinterHelper();
    names = printerHelper.get_PrinterNames();
    if (names != null)
        enumerator = names.GetEnumerator();
        while (enumerator.MoveNext())
            name = enumerator.get_Current();
            info(name);
However, the code which we have learnt to get the list of printers in AX 5.0 will still give the same results in AX 2012.
Just wanted to show another way of getting the printers information in AX 2012 for SSRS printer destinations.
static void SR_2009AXPrinters(Args _args)
    PrintJobSettings pjs;
    SysPrintOptions options = new SysPrintOptions();
    int i;
    str printerName;
    pjs = new PrintJobSettings();
    for (i = 1 ; i <= pjs.getNumberOfPrinters() ; i++)
        printerName = pjs.getPrinter(i);
        pjs.deviceName(printerName);
        info(printerName);
Happy Dax6ng
Последний раз редактировалось Poleax; 16.05.2012 в 12:30. Причина: оформление
За это сообщение автора поблагодарили: Ganna (1).
Dynamics AX Sustained Engineering: Servicing of Dynamics AX 2012 and Dynamics AX 2012 Feature Pack Blog bot DAX Blogs 0 08.05.2012 23:12
dax-lessons: SysTableBrowser customized to show Field List [AX 2012 and 5.0] Blog bot DAX Blogs 0 03.05.2012 19:11
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Dynamics AX Sustained Engineering: Annoucing Cumulative Update 2 for Microsoft Dynamics AX 2012 Blog bot DAX Blogs 6 22.11.2011 20:11
dax-lessons: Create Quick first SSRS report in Dynamics AX 2012 Blog bot DAX Blogs 0 19.08.2011 22:12
Часовой пояс GMT +3, время: 06:34.
