Старый 17.07.2013, 01:20   #1
RVS is offline
RVS
Сенбернар
Аватар для RVS
696 / 130 (6) +++++
Очередная бороьба с Query() (DAX2009)
DAX 2009, 5.0.1500.2985 (Kernel & Appl) EE RU HRP 5.0.1500.2116.1
Развлекаемся..
void initQuery()
Query                   q = new Query();
QueryBuildRange         qbr;
QueryBuildDataSource    qbds;
QueryBuildDataSource    qbdsActivities;
qbdsActivities    q.addDataSource(tablenum(smmActivities));
qbdsActivities.addSelectionField(fieldnum(smmActivitiesN_ProjId));
qbdsActivities.addSelectionField(fieldnum(smmActivitiesStartDateTime));
qbdsActivities.addSelectionField(fieldnum(smmActivitiesEndDateTime));
qbdsActivities.addSelectionField(fieldnum(smmActivitiesN_ItemId));
qbdsActivities.addSelectionField(fieldnum(smmActivitiesN_Dimension));
qbdsActivities.addSelectionField(fieldnum(smmActivitiesN_InventDimId));
qbdsActivities.orderMode(OrderMode::GroupBy);
// TODO RVS : Проект в smmActivities пустой, надо извлекать из smmActivityParentLinkTable ?
    // qbdsActivities.addRange(fieldnum(smmActivities, N_ProjId));
qbr     qbdsActivities.addRange(fieldnum(smmActivitiesN_ActivityStatus));
qbr.value(QueryValue(N_ActivityStatus::Complited));
qbr.status(RangeStatus::Hidden);
qbr qbdsActivities.addRange(fieldnum(smmActivitiesEndDateTime));
qbds    qbdsActivities.addDataSource(tablenum(smmActivityParentLinkTable), 'WrkCtrlLink');
qbds.relations(true);
qbds.joinMode(JoinMode::InnerJoin);
qbr qbds.addRange(fieldnum(smmActivityParentLinkTableParentType));
qbr.value(QueryValue(smmActivityParentType::N_WrkCtr));
qbds    qbds.addDataSource(tablenum(wrkCtrTable));
qbds.orderMode(OrderMode::GroupBy);
qbds.addLink(fieldnum(smmActivityParentLinkTableRefRecId), fieldnum(wrkCtrTableRecId));
qbds.addSelectionField(fieldnum(wrkCtrTableWrkCtrId));
qbr qbds.addRange(fieldnum(wrkCtrTableWrkCtrType));
qbr.value(QueryValue(WrkCtrType::Personnel));
    // TODO RVS : Проверяем возможность прицепить источник данных "не в лесенку"
    qbds    = qbdsActivities.addDataSource(tablenum(smmActivityParentLinkTable), 'ProjLink');
    qbr = qbds.addRange(fieldnum(smmActivityParentLinkTable, ParentType));
    qbr.value(QueryValue(smmActivityParentType::Project));
    qbds    = qbds.addDataSource(tablenum(ProjTable));
    qbds.addSelectionField(fieldnum(ProjTable, ProjId));
    qbds.addLink(fieldnum(smmActivityParentLinkTable, RefRecId), fieldnum(ProjTable, RecId));
    qbr = qbds.addRange(fieldnum(ProjTable, ProjId));
info(q.dataSourceNo(1).toString());
queryRun = new SysQueryRun(q);
Имеем запрос :
SELECT FIRSTFAST N_ProjId, StartDateTime, EndDateTime, N_ItemId, N_Dimension, N_InventDimId FROM smmActivities WHERE ((N_ActivityStatus = 6)) JOIN FIRSTFAST * FROM smmActivityParentLinkTable WHERE smmActivities.ActivityNumber = smmActivityParentLinkTable.ActivityNumber AND ((ParentType = 18)) JOIN FIRSTFAST WrkCtrId FROM WrkCtrTable WHERE smmActivityParentLinkTable.RefRecId = WrkCtrTable.RecId AND ((WrkCtrType = 1))
... что неплохо, только хочется еще группировку по Проекту, который тоже приделан к smmActivity через smmActivityParentLinkTable ..
Убираем комментарий с TODO в коде :
void initQuery()
    qbdsActivities    = q.addDataSource(tablenum(smmActivities));
    qbdsActivities.addSelectionField(fieldnum(smmActivities, N_ProjId));
    qbdsActivities.addSelectionField(fieldnum(smmActivities, StartDateTime));
    qbdsActivities.addSelectionField(fieldnum(smmActivities, EndDateTime));
    qbdsActivities.addSelectionField(fieldnum(smmActivities, N_ItemId));
    qbdsActivities.addSelectionField(fieldnum(smmActivities, N_Dimension));
    qbdsActivities.addSelectionField(fieldnum(smmActivities, N_InventDimId));
    qbr     = qbdsActivities.addRange(fieldnum(smmActivities, N_ActivityStatus));
    qbr = qbdsActivities.addRange(fieldnum(smmActivities, EndDateTime));
    qbds    = qbdsActivities.addDataSource(tablenum(smmActivityParentLinkTable), 'WrkCtrlLink');
    qbds    = qbds.addDataSource(tablenum(wrkCtrTable));
    qbds.addLink(fieldnum(smmActivityParentLinkTable, RefRecId), fieldnum(wrkCtrTable, RecId));
    qbds.addSelectionField(fieldnum(wrkCtrTable, WrkCtrId));
    qbr = qbds.addRange(fieldnum(wrkCtrTable, WrkCtrType));
, имеем в итоге :
Что-то я вообще уже ничего не понимаю..
PS : Понятно, что это утверждение, а не вопрос.
Чего хотелось :
Построить запрос типа :
smmActivity
-->> smmActivityParentLinkTable (фильтр по связям с Рабочими центрами, группировка)
-->> smmActivityParentLinkTable (фильтр по связям с Проектами, группировка)
Собственно, и все.
Вопрос :
- это можно вообще? В Query() ? В Скул-е - можно, я знаю..
- если Да - что я делаю не так?
Best Regards,
Roman
Последний раз редактировалось RVS; 17.07.2013 в 01:57.
Старый 17.07.2013, 02:25   #2
db is offline
db
Роман Долгополов (RDOL)
393 / 692 (24) +++++++
попробуйте после каждого qbds.joinMode() добавить еще и qbds.fetchMode(QueryFetchMode::One2One).Да и вообще добавлять эту конструкцию стоит всегда и везде по умолчанию.
очень похоже что ядро решило разложить запрос на вложенные друг в друга отдельные запросы,а режим по умолчанию QueryFetchMode::One2Many это не запрещает
Последний раз редактировалось db; 17.07.2013 в 02:28.
За это сообщение автора поблагодарили: RVS (2).
Старый 17.07.2013, 09:24   #3
Сообщение от RVS Посмотреть сообщение
Чего хотелось :
Совет:
не занимайтесь программированием запросов с нуля.
тупо создайте объект в AOT. укажите в объекте AOT неободимые свойства и параметры.
затем вместо кучи кода по созданию Query сделайте просто
Query q = new Query(querystr(mySuperQuery));
в коде только модифицируйте те критерии, которые действительно нужно менять.
так и вопросов будет меньше, и запросы будет создавать намного легче, и поддерживать на порядок проще.
За это сообщение автора поблагодарили: RVS (2), MikeR (2), sashanka (1).
Старый 17.07.2013, 23:07   #4
RVS is offline
RVS
Сенбернар
Аватар для RVS
696 / 130 (6) +++++
Сообщение от db Посмотреть сообщение
Спасибо, помогло
Best Regards,
Roman
ax-erp: How to Set the Query Range on a SSRS Report Blog bot DAX Blogs 0 18.10.2012 19:11
emeadaxsupport: Calling the Query Service Blog bot DAX Blogs 0 18.02.2012 01:13
AIF: OData Query Service Blog bot DAX Blogs 0 24.08.2011 09:11
jinx: Dynamics AX – Query-Ranges und Filtereinstellungen des Benutzers Blog bot DAX auf Deutsch 0 04.02.2010 00:05
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 04.05.2009 14:05
Часовой пояс GMT +3, время: 09:02.
