09.06.2021, 15:08 | #1 |
Как включить FeatureLifecycle Ax 365
Привет
Имеем некие траблы вызванные предположительно кривостью который вроде в МС поправили https://fix.lcs.dynamics.com/Issue/D...9&bugId=483453 Use AppTroubleshooting to block when TaxUncommitted is inserted without referenced SourceDocumentLine inserted, or TaxUncommitted is deleted without referenced SourceDocumentLine deleted Рекомендуется Enable TaxConsistencyCheckTaxUncommittedOnInsertedFlighting and TaxConsistencyCheckTaxUncommittedOnDeletedFlighting to use AppTroubleshooting to block when TaxUncommitted is inserted without referenced SourceDocumentLine inserted, or TaxUncommitted is deleted without referenced SourceDocumentLine deleted. В фичах данных хреней не увидел но в коде они есть. Как довольно странные фичи. TaxConsistencyCheckTaxUncommittedOnDeletedFlighting implements IFeatureLifecycle Вопрос как их включить? |
09.06.2021, 16:09 | #2 |
FeatureLifecycleStage::PrivatePreview;
https://docs.microsoft.com/en-us/dyn...ement-overview Цитата:
What is feature flighting and how does it relate to feature management?
Feature flights are real-time on/off switches that Microsoft controls. They are separate from the customer control provided by Feature Management. Private Preview features will not be listed in Feature Management until they are flighted on. In production, the customer needs to agree to be part of a special program for that to occur. Public Preview and Released (generally available) features will be listed in Feature Management unless they are flighted off. Flighting a feature off is considered a last resort option for product teams if a critical issue is found and would usually be a per-customer operation. |
За это сообщение автора поблагодарили: trud (2), axm2017 (4). |
09.06.2021, 16:21 | #3 |
Охренеть.
То есть это тайные фичи которые не включаются, если не вживишь себе чип от Билла. даже если купил продукт. Заодно не самое слабое попадание для onPrem |
09.06.2021, 19:23 | #4 |
Теги |
feature, featurelifecyclestage, flight, flighting, private preview |
Опции просмотра | |
