03.04.2007, 15:36 | #13 |
Для Builder'а не знаю, но для VisualC можно так
Файл "aosmgr.h" X++: #ifndef _AOSMGR_H_ #define _AOSMGR_H_ #ifdef __cplusplus extern "C" { #endif /* __cplusplus */ #include <windef.h> typedef UINT (CALLBACK * LPFNDLLAOSSTATUS)(char* Host, char* AOSname); typedef UINT (CALLBACK * LPFNDLLAOSSTART)(char* Host, char* AOSname); typedef UINT (CALLBACK * LPFNDLLAOSSTOP)(char* Host, char* AOSname); #ifdef __cplusplus } #endif /* __cplusplus */ #endif X++: // AxAosMgr.cpp : Defines the entry point for the console application. // #include "stdafx.h" #include <windef.h> #include <winbase.h> #include <winuser.h> #include <malloc.h> #include "aosmgr.h" char * GetStatusStr(int _status) { switch (_status) { case 1: return "AOS остановлен"; case 2: return "AOS запускается"; case 3: return "AOS останавливается"; case 4: return "AOS запущен"; case -1: return "Connection timed out"; case -2: return "Connection refused"; case -3: return "Protocol error"; case -4: return "Server manager not started"; case -5: return "AOS stopped"; case -6: return "AOS start pending"; case -7: return "AOS stop pending"; case -8: return "AOS running"; case -9: return "AOS not found on server"; case -10: return "Cannot assign requested address"; case -11: return "Unknown TCP error"; case -12: return "AOS unknown status"; case -13: return "Access denied"; case -14: return "Service error"; case -15: return "Invalid Axapta Service Name"; case -16: return "Service Does Not Exist"; case -17: return "Service Not Started"; case -18: return "Server Unavailable"; default: return "Unknown status"; } } int _tmain(int argc, _TCHAR* argv[]) { HINSTANCE hDLL; LPFNDLLAOSSTATUS AOSStatus; LPFNDLLAOSSTART AOSStart; LPFNDLLAOSSTOP AOSStop; char* msg; hDLL = LoadLibrary("AosMgr.dll"); if (hDLL != NULL) { AOSStatus = (LPFNDLLAOSSTATUS)GetProcAddress(hDLL, "AosStatus"); if (!AOSStatus) { FreeLibrary(hDLL); return -1; } /* AOSStart = (LPFNDLLAOSSTART)GetProcAddress(hDLL, "AosStart"); AOSStop = (LPFNDLLAOSSTOP)GetProcAddress(hDLL, "AosStop");*/ msg = GetStatusStr(AOSStatus("Axapta", "Axapta")); if (msg) { char * buf = (char*) malloc(strlen(msg)+1); strcpy(buf, msg); CharToOem(buf, buf); printf("%s\n", buf); free(buf); } } return 0; }
Axapta v.3.0 sp5 kr2 |
Теги |
aos, ax3.0, download, faq, администрирование, законченный пример |
