#4 |
I hardly think you can setup any kind of a trigger to monitor such changes. You can periodically copy current application to the old directory, then query for UtilElements for table fields that where changed since the last copying and compare such fields with the ones in the old layer to find out which properties have been changed... Or you can use a VCS.
