Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 22.02.2012, 17:41   #1
ist is offline
ist
Different labels depends on company
Hello Guys,
Is there any way AX dimension labels to be dependent on company?
For example in one company Dimension[1] to be "Department", but in another company to be "Purpose".
I thing It's not possible, but hwo knows...
There is workaround to use different languages, but I donn't like this idea!
Regards,
10x
Старый 23.02.2012, 10:39   #2
S.Kuskov is offline
S.Kuskov
3,434 / 1775 (66) ++++++++
You can try to change the label of controls in the RunTime.
SysSetupFormRun + Итератор с поддержкой методов обратного вызова для обработки контролов на форме
Старый 23.02.2012, 15:46   #3
ist is offline
ist
Thanks for your idea, but this is the case only for forms. And reports...?
I'm searching for solution in general.
Regards,
Старый 24.02.2012, 00:31   #4
Link is offline
Link
Британский учённый
Аватар для Link
568 / 513 (19) +++++++
Записей в блоге: 9
Сообщение от ist Посмотреть сообщение
Hello Guys,
Regards,
10x
Just as an idea: if your environment allows you to have a separate application for each company (dedicated AOS per company), than you can define a separate label for each one by overriding the system label on the object. However this is not a good solution.
I can't see a simple way. The languages that you have mentioned also required additional license.
Старый 24.02.2012, 15:03   #5
gl00mie is offline
gl00mie
3,684 / 5798 (201) ++++++++++
It's not necessary to use a two (or more) physical copies of application files in that scenario. You can have two different application folders but application files in one of them can be just hardlinks to the same files in the other folder and only label files can differ. In that case AOSes that use both of the application folders will actually work with the same «physical» application files so that you wouldn't have to sync the applications (which is vital if two or more applications are used with the same database). But anyway such an approach requires very careful application maintenance.
За это сообщение автора поблагодарили: Link (2).
dynamicscpm: Company Integration - Management Reporter 2012 Feature Highlight Blog bot DAX Blogs 0 21.02.2012 08:11
emeadaxsupport: Long running process switches from one company to another company Blog bot DAX Blogs 0 27.01.2010 20:05
dynamicsaxtraining: Create new company. Demo data Blog bot DAX Blogs 0 19.11.2009 14:05
emeadaxsupport: Query execution failed for data set 'Company' Blog bot DAX Blogs 0 28.10.2009 00:06
Часовой пояс GMT +3, время: 13:01.
