Старый 22.03.2018, 10:11   #1
25,494 / 847 (79) +++++++
waldo: AL with VSCode: IntelliSense Fix
Источник: http://dynamicsuser.net/nav/b/waldo/...tellisense-fix
Since a recent update of VSCode, you might have noticed that IntelliSense works somewhat different. Well, that’s because VSCode thought to do a good, useful update for you .. but apparently for AL development, it turns out to be quite contra productive..
CTRL+Space
You all probably know why CTRL+Space is for? It’s for forcing IntelliSense. Or the official term is “Trigger Suggest“. In a context-aware intellisense, it’s very useful to get suggestions on which keywords can be used in a certain context.
Since one of the latest updates of VSCode, the default behaviour has somewhat changed. When you “trigger suggest” (press CTRL+Space), it will point to the last one used.
Like in this example, I use the snippet “tprocedure”, and when I use the CTRL+Space to start coding, you will see it will jump straight to the “tprocedure”-item in the list, just because I just used it:
In a context-aware in IntelliSense, this just doesn’t make any sense.
You can fix this
VSCode wouldn’t be VSCode if you couldn’t fix this behaviour. And I have a strong feeling you would like to fix it ;-). It’s simple, just add following setting in your settings.json (File / Preferences / Settings):
As the tooltip explains: Editor.suggestSelection controls how the suggestions are pre-selected when showing the suggest list. In this case it will always select the first suggestion.
This means it will always suggest the first item in the IntellSense-list. Just the way you would expect (in my opinion). Let’s see what this means for our example:
Thanks Esben & Stan
When I was doing my session in Bangkok last week, Esben and Stan saw me struggling with this, and gave me the solution. :-). Thanks so much!
waldo: AL with VSCode: ExportToNewSyntax Blog bot NAV: Blogs 0 07.08.2017 04:17
waldo: AL with VSCode: Run Extension Objects (with PowerShell) Blog bot NAV: Blogs 0 14.06.2017 04:17
waldo: AL with VSCode: Symbol Rename Blog bot NAV: Blogs 0 22.05.2017 05:12
waldo: Convert C/AL Objects to AL with PowerShell Blog bot NAV: Blogs 0 05.05.2017 03:33
waldo: Microsoft Dynamics NAV 2017 – what’s really new? Blog bot NAV: Blogs 0 13.10.2016 05:22
Часовой пояс GMT +3, время: 14:11.
