#1 |
Еще для вдохновения:
1. Packing slip X++: SalesFormLetter salesFormLetter; SalesParmUpdate salesParmUpdate; SetEnumerator set; CustPackingSlipJour custPackingSlipJour; SysQueryRun chooseLines; salesFormLetter = SalesFormLetter::construct(DocumentStatus::PackingSlip); salesFormLetter.getLast(); salesFormLetter.resetParmListCommonCS(); salesFormLetter.proforma(false); salesFormLetter.createParmUpdateFromParmUpdateRecord( SalesFormletterParmData::initSalesParmUpdateFormletter( DocumentStatus::PackingSlip, salesFormLetter.pack())); salesParmUpdate = salesFormLetter.salesParmUpdate(); salesParmUpdate.SpecQty = SalesUpdate::DeliverNow; salesParmUpdate.Proforma = NoYes::No; if(salesParmUpdate.SumBy == AccountOrder::Order) { salesParmUpdate.SumSalesId = _sumSalesId; } salesParmUpdate.update(); salesFormLetter.salesParmUpdate(salesParmUpdate); chooseLines = this.calcQuery(); // Custom Query salesFormLetter.chooseLinesQuery(chooseLines); salesFormLetter.reArrangeNow(true); salesFormLetter.validateAll(false); salesFormLetter.chooseLines(); salesFormLetter.run(); set = Set::create(SysOperationHelper::base64Decode(salesFormLetter.getOutputContract().parmAllJournals())).getEnumerator(); while (set.moveNext()) { custPackingSlipJour = set.current(); break; } return custPackingSlipJour.PackingSlipId; X++: public SysQueryRun calcQuery() { Query q = new Query(queryStr(SalesUpdate)); QueryBuildDataSource qbds; qbds = q.dataSourceTable(tableNum(SalesLine)); ... join your table ... return new SysQueryRun(q); } X++: SalesFormLetter salesFormLetter; SalesParmUpdate salesParmUpdate; CustPackingSlipJour custPackingSlipJour; TmpFrmVirtual tmpFrmVirtual; List selectedList = new List(Types::Record); SalesParmTable salesParmTable; select firstonly RecId, TableId from custPackingSlipJour where custPackingSlipJour.PackingSlipId == _consolidatedPackingSlipId; tmpFrmVirtual.clear(); tmpFrmVirtual.TableNum = custPackingSlipJour.TableId; tmpFrmVirtual.RecordNo = custPackingSlipJour.RecId; tmpFrmVirtual.NoYes = NoYes::Yes; tmpFrmVirtual.Id = _sumSalesId; tmpFrmVirtual.insert(); selectedList.addEnd(tmpFrmVirtual); salesFormLetter = SalesFormLetter::construct(DocumentStatus::Invoice); salesFormLetter.selectFromJournal(selectedList.pack()); salesFormLetter.specQty(SalesUpdate::PackingSlip); salesFormLetter.run(); |
За это сообщение автора поблагодарили: trud (5). |
