Старый 09.06.2021, 15:08   #1
axm2017 is offline
axm2017
1,764 / 293 (13) ++++++
Как включить FeatureLifecycle Ax 365
Привет
Имеем некие траблы вызванные предположительно кривостью который вроде в МС поправили
https://fix.lcs.dynamics.com/Issue/D...9&bugId=483453
Use AppTroubleshooting to block when TaxUncommitted is inserted without referenced SourceDocumentLine inserted, or TaxUncommitted is deleted without referenced SourceDocumentLine deleted
Рекомендуется
Enable TaxConsistencyCheckTaxUncommittedOnInsertedFlighting and TaxConsistencyCheckTaxUncommittedOnDeletedFlighting to use AppTroubleshooting to block when TaxUncommitted is inserted without referenced SourceDocumentLine inserted,
or TaxUncommitted is deleted without referenced SourceDocumentLine deleted.
В фичах данных хреней не увидел но в коде они есть.
Как довольно странные фичи.
TaxConsistencyCheckTaxUncommittedOnDeletedFlighting implements IFeatureLifecycle
Вопрос как их включить?
Старый 09.06.2021, 16:09   #2
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
FeatureLifecycleStage::PrivatePreview;
https://docs.microsoft.com/en-us/dyn...ement-overview
What is feature flighting and how does it relate to feature management?
Feature flights are real-time on/off switches that Microsoft controls. They are separate from the customer control provided by Feature Management.
Private Preview features will not be listed in Feature Management until they are flighted on. In production, the customer needs to agree to be part of a special program for that to occur.
Public Preview and Released (generally available) features will be listed in Feature Management unless they are flighted off. Flighting a feature off is considered a last resort option for product teams if a critical issue is found and would usually be a per-customer operation.
За это сообщение автора поблагодарили: trud (2), axm2017 (4).
Старый 09.06.2021, 16:21   #3
axm2017 is offline
axm2017
Охренеть.
То есть это тайные фичи которые не включаются, если не вживишь себе чип от Билла. даже если купил продукт. Заодно не самое слабое попадание для onPrem
Старый 09.06.2021, 19:23   #4
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Сообщение от axm2017 Посмотреть сообщение
Это не выпущенные официально для всех фичи. Все равно что поставить windows insider или типа того.
feature, featurelifecyclestage, flight, flighting, private preview
patrickmouwen: Dynamics AX Retail 3rd party POS and E-commerce integration – Solution Design Blog bot DAX Blogs 0 26.10.2015 12:11
axinthefield: Compatibility Testing for Microsoft Dynamics AX Blog bot DAX Blogs 0 23.06.2012 02:26
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Часовой пояс GMT +3, время: 14:48.
