Старый 22.06.2021, 07:19   #1
25,491 / 846 (79) +++++++
TF command line to fix the error: Mapping on the working folder is already in use
Источник: http://alexvoy.blogspot.com/2021/06/...apping-on.html
Just to document my command line to get rid of this blocking error.
My environment is under Azure DevOps version control and some other user already created a workspace on this computer.
Close Visual Studio (2017 in my case) and open the command line. It can be open via Developer Command Prompt for VS 2017; so you would not need to provide the entire path to tf.exe.
Next, run a tf command to delete the workspace created by the previous user (Name and Surname)
tf workspace /delete DEV365-FO-VM-3;"Name Surname" /collection:https://YOURCOMPANYPROJECT.visualstudio.com
Then stop all locally running D365FO services, like Web Publishing, Batch processing, etc, in order to avoid errors with locked files in your K:\AosService\PackagesLocalDirectory subfolders.
Now you can open Visual Studio, connect to Azure DevOps server, create a new workspace, map your folders for projects and metadata, and get latest.
d365fo, devops, visual studio
dynamicsax-fico: Timesheets & missing working time Blog bot DAX Blogs 0 06.12.2016 19:13
crminthefield: Automate creating a CRM 2013 Redist folder to install CRM 2013 without an internet connection Blog bot Dynamics CRM: Blogs 0 21.11.2013 19:11
crminthefield: Use PowerShell: build a redist folder to install Dynamics CRM 2011 without an internet connection Blog bot Dynamics CRM: Blogs 0 15.08.2013 01:16
crminthefield: Reminders not working with Outlook 2010 SP1 and CRM 2011–Fix Available Blog bot Dynamics CRM: Blogs 0 13.09.2011 03:34
Часовой пояс GMT +3, время: 02:03.
