Старый 25.08.2018, 18:21   #1
25,477 / 846 (79) +++++++
d365technext: Bar Code in SSRS Report D365FO
Источник: http://d365technext.blogspot.com/201...rt-d365fo.html
Following are the simple steps to generate Bar-Code in SSRS report.
In SSRS temporary table, Bar-Code filed should be extended with BarCodeString EDT.
Use font >BC C128 Narrow
Field in SSRS should be well space otherwise bar-code scan will not work
Using following code you can generate bar-code of any value...
Example: xyzTableBuffer.BarCodeField= this.getBarcode("123456789")
publicstr getBarcode(str _barCodeText)
BarcodeCode128 barcode;
barcode = Barcode::construct(BarcodeType::Code128);
barcode.string(true, _barCodeText);
barcode.encode();
return barcode.barcodeStr();
UAT Deployment
Please feel free to contact me if you are facing any issue during implementation of the blog
Старый 21.09.2021, 21:54   #2
user_ax is offline
user_ax
Аватар для user_ax
599 / 39 (3) +++
Помогла статья, благодарю.
d365technext: SSRS Report with custom fonts in D365FO Blog bot DAX Blogs 0 15.08.2018 17:15
d365technext: Camel case on SSRS Report Expression, D365FO Blog bot DAX Blogs 0 12.08.2018 11:18
d365technext: Customization Analysis Report D365FO Blog bot DAX Blogs 0 09.08.2018 17:11
Часовой пояс GMT +3, время: 18:44.
