Старый 20.07.2012, 00:11   #1
25,486 / 846 (79) +++++++
ax-erp: Adding a role to all or multiple users using X++ Code [Dynamics AX 2012]
Источник: http://microsoft-dynamics-ax-erp.blo...ple-users.html
Friends,
In AX 2012, we can add a role to all the users by running the automated role assignment job based on the rule which we define in the “Assign users to Role” form.
Navigation : System administration >> Setup >> Security >> Assign users to roles
And the code behind this is :
SysSecurityDynamicRoleAssignment::synchronize(args.record().RecId); // selected Role (this is Security Role table buffer) in the form
I tried to run the above code independently by passing the “Budget clerk” Security Role but did not work due to obvious reasons as it needed a rule assignment table buffer.
The equivalent code to assign a role to all users is below.
This doesn’t need to add any rules like what we do in the form.This is just an experiment to handle the roles through code and request to test the code before using it.
staticvoid SR_AssignRoleToAllUsers(Args _args)
SecurityRole role;
SecurityUserRole userRole;
boolean added;
UserInfo userInfo;
select role where role.Name == ‘Budget clerk’;
whileselect userInfo
select * from userRole
where userRole.SecurityRole == role.RecId &&
userRole.User == userInfo.id;
if (!userRole || (userRole.AssignmentStatus != RoleAssignmentStatus::Enabled))
info(strFmt(‘Role %1 added to the user %2 successfully.’, role.Name, userInfo.id));
userRole.User = userInfo.id;
userRole.SecurityRole = role.RecId;
userRole.AssignmentMode = RoleAssignmentMode::Manual;
userRole.AssignmentStatus = RoleAssignmentStatus::Enabled;
SecuritySegregationOfDuties::assignUserToRole(userRole, null);
else
warning(strFmt(‘skipping – Role %1 to the user %2.’, role.Name, userInfo.id));
Happy dax6ng,
Sreenath Reddy
dax-lessons: Adding a role to all or multiple users using X++ Code [Dynamics AX 2012] Blog bot DAX Blogs 0 27.04.2012 22:11
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Часовой пояс GMT +3, время: 15:50.
