23.07.2020, 08:53 | #5 |
Там данные с 2012 года, т.е. перезакрыть будет проблематично. Похоже "On-hand entries aggregation by financial dimensions" предложенное Vadik как раз то что нужно. Спасибо
If you for example use Batch numbers, each batch number (and the combined site, warehouse, etc.) creates a new record in InventSum. When the batch number is sold, you will see quantity fields are set to 0. In most cases, the Financial/Physical value field is also set to 0, but in Standard cost revaluation or other scenarios, the value field may show some amount still. This is valid, and is the way Dynamics 365 for Finance and Operations handles the costs on Financial inventory level, e.g. site level.
За это сообщение автора поблагодарили: Logger (1). |
