Старый 17.04.2019, 05:18   #1
25,477 / 846 (79) +++++++
crmtipoftheday: Tip #1254: Design Dynamics 365 email templates with the new email editor
Источник: https://crmtipoftheday.com/1254/desi...-email-editor/
In a recent virtual conversation with Steve Mordue, Steve inquired about using the new Unified Interface email editor to create email templates.
While Microsoft has not (yet) gotten around to adding the template creation process to unified interface, there is at least one approach you can take to design your templates in the new email editor.
  1. Create an email in Unified Interface
  2. Add your fancy schmancy formatting
  3. CTRL+a and CTRL+c to select all of the contents of the email body/description.
  4. Create a new email template in the Advanced Settings area.
  5. Select the template body field and CTRL+v to paste the contents.
This will maintain most of the formatting, including images. You can then add in your template specific merge fields.
crmtipoftheday: Tip #1138: Obtenga your Dynamics 365 trial dans la правильном Sprache Blog bot Dynamics CRM: Blogs 0 20.07.2018 14:11
crmtipoftheday: Tip #1091: Dynamics 365 App for Outlook version 9.0 is now available Blog bot Dynamics CRM: Blogs 0 22.03.2018 22:13
crmtipoftheday: Tip #1041: Make Dynamics 365 data import less rigid Blog bot Dynamics CRM: Blogs 0 11.12.2017 03:41
Microsoft Dynamics CRM Team Blog: Adding attachments to Templates and Bulk email Blog bot Dynamics CRM: Blogs 1 29.12.2010 15:43
Часовой пояс GMT +3, время: 03:38.
