Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 29.02.2012, 20:34   #1
ideveloper is offline
ideveloper
Create XML-Export with AIF
Hi everybody.
We need to create a XML-Export from the invoice table which have a custom XSD-schema.
Could we achieve it using the AIF Objects which we create based on the query running the AIF-Wizard (without the webservices)
If yes, how can we do it?
(You can anser in russian too)
Старый 29.02.2012, 21:10   #3
ideveloper
Is it possible to call AIF functions without creating and consuming the webservice???
Старый 01.03.2012, 05:46   #4
kaw is offline
kaw
See form AifAdapter
AIF can export: AifWebServiceAdapter / AifMSMQAdapter / AifBizTalkAdapter / AifFileSystemAdapter
Use last
see also
Document Schema Rules
Generate a Document Schema
Старый 01.03.2012, 14:41   #5
ideveloper
After a couple of hours I found the following link with a detailed explanation of calling AIF-Functions from a button:
http://www.dynamicscare.com/blog/ind...d-aif-document
I think using the AifFileSystemAdapter and customizing outbound pipelines should be the solution.
Is it possible to get the filename of the XML-Message which was saved by the AifFileSystemAdapter?
За это сообщение автора поблагодарили: S.Kuskov (1).
Старый 01.03.2012, 15:26   #6
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1849 (69) ++++++++
Provided that AIF is set up, all you need to do to push sales invoice while posting it is customizing SalesFormLetter_Invoice.updateNow() (see also printJournal() method):
boolean updateNow()
    this.postJournal();
    if (custInvoiceJour.canXMLBeSent())
        custInvoiceJour.sendElectronically(XMLDocPurpose::Original, AifSendMode::Async);
    #if.never//    #speedtest
    if (speedExecute_Sales)
        speedExecute_Sales.timing(SpeedSalesTiming::InvoiceEnd,'');
    #endif
    return true;
-ТСЯ или -ТЬСЯ ?
Старый 02.03.2012, 12:03   #7
kaw is offline
kaw
Сообщение от ideveloper Посмотреть сообщение
When you send document, add record to table AifOutboundProcessingQueue.
The next stage of the, start
new AifOutboundProcessingService().run();
new AifGatewaySendService().run();
and the system generates filename, see:
AifFileSystemSendAdapter. getNewOutFileName
AifFileSystemSendAdapter. sendMessage
How you want to use filename ?
Старый 02.03.2012, 13:00   #8
ideveloper
We have a job to send a XML file to the customer per email.
Therefor we must map the data to a predefined XML schema.
The idea was to use the queries and classes of the AIF to create the standard XML Message and use the transformation abilities (after the answers here) of the outbound pipeline to map the XML mesasge into another schema.
The another idea is using the job to gererate the XML file through the AIF BizTalk (or File) Adapther which will be send the XML message to BizTalk.
Последний раз редактировалось ideveloper; 02.03.2012 в 13:06.
Старый 05.03.2012, 10:18   #9
kaw is offline
kaw
Maybe, create AifFileSystemSendMailAdapter extends AifFileSystemAdapter
And into AifFileSystemSendAdapter.sendMessage – send Email partner
... and use the transformation abilities (after the answers here) of the outbound pipeline to map the XML mesasge into another schema.
I don't like this idea.
or configure “classes of the AIF to create” the XML Message required schema.
or use BizTalk
aif
emeadaxsupport: Cannot create Enterprise portal site with SharePoint 2010. Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml' Blog bot DAX Blogs 0 15.08.2011 23:11
emeadaxsupport: Error when trying to register the AIF services - "Cannot create a record in Data Policy Schema Information (AifDocumentField)" Blog bot DAX Blogs 0 29.03.2010 21:05
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 19.10.2008 18:05
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 25.03.2008 03:58
Часовой пояс GMT +3, время: 16:58.
