Старый 31.03.2015, 21:12   #1
25,510 / 847 (80) +++++++
emeadaxsupport: How to: Automatically assigning a Load template ID to a load in Microsoft Dynamics AX 2012 R3
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r3.aspx
This blog post assumes the readers are familiar with the new
Warehouse Management (WMS) and Transportation Management Module (TMS) in
Microsoft Dynamics AX 2012 R3.
The creation of loads for sales orders, transfer orders and
purchase orders is a process that can be completed manually or automatically
upon the creation of a document. In both cases a user is require to manually
assign a Load Template ID to the load so that key information from the template
can be referenced throughout the processing of the load. Manually assigning the
Load Template ID may not be a sustainable process for many customers. With a
little setup the system will automatically assign the Load Template ID to a
load based on Item Group.
To configure a particular Item Group to use a
specific Load Template follow these steps:
1) Navigate to Warehouse management | Setup | Load
| Item load mapping
2) In the Item load mapping form click New
a. Item group = Audio (select and item group)
b. Load template ID = Stnd Load Template
With the mapping in place new loads that are created for items that belong to the “Audio” item group will
automatically have the "Stnd Load Template" template.
emeadaxsupport: How to use the Manual Billing Rule for Projects in Microsoft Dynamics AX 2012 R2 and AX2012 R3 Blog bot DAX Blogs 0 03.03.2015 19:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 11 Blog bot Dynamics CRM: Blogs 0 06.10.2012 05:27
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 7 Blog bot Dynamics CRM: Blogs 0 27.03.2012 02:11
Часовой пояс GMT +3, время: 06:34.
