Старый 07.09.2021, 13:14   #1
25,475 / 846 (79) +++++++
crmtipoftheday: Tip #1413: Components Required in the Solution for Relationship Mapping Deployment
Источник: https://crmtipoftheday.com/1413/comp...ing-deployment
Today’s winner is Linn Zaw “I always” Win. And you can be one too if you email your tip to jar@crmtipoftheday.com!
Have you ever added the 1:N or N:1 relationship into the solution, created new mappings in the solution and deployment the solution to another environment only to find out that the mappings are not deployed? Upon opening the customizations.xml of the solution, you might notice that the newly created mappings are not included under the tag.
These are the components required in the solution to include the relationship mapping.
  1. Relationship which contains the mapping (obviously)
  2. Both Primary and Related tables of the relationship
  3. Target column of the mapping
Relationship
Mapping
Tables and target column
Cover photo by Davies Designs Studio on Unsplash
crmtipoftheday: Tip #1380: “Sign in required” error when signing in to Power Apps Blog bot Dynamics CRM: Blogs 0 07.09.2020 17:11
crmtipoftheday: Tip #1366: Make file type field required Blog bot Dynamics CRM: Blogs 0 17.06.2020 14:11
crmtipoftheday: Tip #1294: Export solution before running solution checker Blog bot Dynamics CRM: Blogs 0 13.08.2019 18:12
crmtipoftheday: Tip #1157: Do not delete system components Blog bot Dynamics CRM: Blogs 0 22.08.2018 14:11
crmtipoftheday: Tip #1076: Add all assets to your solution Blog bot Dynamics CRM: Blogs 0 15.02.2018 09:11
Часовой пояс GMT +3, время: 10:04.
