Старый 09.09.2021, 16:11   #1
25,475 / 846 (79) +++++++
crmtipoftheday: Tip #1414: Enforce unique email but ignore inactive records
Источник: https://crmtipoftheday.com/1414/enfo...inactive-users
Alternate keys are great way to enforce uniqueness of the column values. For example, if you want lead emails to be truly unique, just add an alternate key and no user will be able to bypass that (unlike the duplicate detection which is a fairly timid mechanism). The challenge is when you want that uniqueness to apply only to active records. Bear with me.
You thought that lead was lost forever and deactivated the record (you do not ever delete important records, right?). Now they are coming back, rejuvenated and refreshed and ready to buy not one but seven of your wonderful Jigamagigs. New lead is created but with the same email and that’s OK – we don’t hold grudges. What you don’t want is two active leads with the identical emails.
Alternate key using email are not going to work for you in this scenario, but you can enforce the uniqueness using a faux column that contains email for active records and null for inactive.
It works because alternate keys ignore null values.
The walkthrough below uses the contact table.
<ol>Create a column large enough to hold email addresses. No need to make it searchable or enable audit.
Create new real-time workflow (and you can do that from the new solution explorer)
crmtipoftheday: Tip #1400: Excluding inactive records from duplicate detection Blog bot Dynamics CRM: Blogs 0 03.02.2021 18:11
crmtipoftheday: Tip #1299: Split email personalities Blog bot Dynamics CRM: Blogs 0 02.09.2019 14:11
crmtipoftheday: Tip #1254: Design Dynamics 365 email templates with the new email editor Blog bot Dynamics CRM: Blogs 0 17.04.2019 05:18
crmtipoftheday: Tip #1026: Change your perspective on tracking email Blog bot Dynamics CRM: Blogs 0 20.11.2017 09:11
crmtipoftheday: Tip #1018: Automatically create Dynamics 365 records from Social Engagement Blog bot Dynamics CRM: Blogs 0 08.11.2017 18:11
Часовой пояс GMT +3, время: 04:31.
