02.05.2009, 14:06 | #1 |
DeniZone: Opening a form on start up of AX
Источник: http://denizone.blogspot.com/2009/05...-up-of-ax.html
============== I've recently implemented a variation of Palle Agermark's post on how to run a form on start up of AX. He opens a form through calling the Display menu item. I needed was to call a form with conditions, so I created a class which would handle the conditions in question and instead of calling the menu item I called the main method of the class Thanks to GregP for his helpful tips and insisting that he could get it to work Источник: http://denizone.blogspot.com/2009/05...-up-of-ax.html
04.05.2009, 12:36 | #2 |
полный список startup команд http://axapta.mazzy.ru/lib/startupcmd_ax4/
Теги |
blog, startup command, axapta |
