Старый 08.05.2020, 04:12   #1
25,487 / 846 (79) +++++++
crmtipoftheday: Tip #1352: Can’t create a trial database?
Источник: https://crmtipoftheday.com/1352/cant...trial-database
You create a Power Apps trial at www.powerapps.com, but if you try to create an environment with a CDS database you get an error that adding a database requires at least 1 GB of free space.
The reason you are getting this error is because when you create the environment, you choose what type of environment it is, and the default choice is sandbox. Sandbox environments require that you have paid storage capacity. But if you choose “trial” for the environment type, you should be able to create your environment with no problem.
Tîpp Jäår $0.02 + GST
What sets the trial aside is that it’s a time-limited environment. It will expire in 1 month unless you convert it into a production environment. Sandbox is treated the same as production, i.e. it does not expire.
crmtipoftheday: Tip #1138: Obtenga your Dynamics 365 trial dans la правильном Sprache Blog bot Dynamics CRM: Blogs 0 20.07.2018 14:11
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
crmtipoftheday: Tip #1018: Automatically create Dynamics 365 records from Social Engagement Blog bot Dynamics CRM: Blogs 0 08.11.2017 18:11
Часовой пояс GMT +3, время: 21:59.
