Старый 01.02.2022, 03:40   #1
25,497 / 847 (79) +++++++
butenko.pro: Adding a PCF Control to the Dataverse Application Navigation (SiteMap)
Источник: https://butenko.pro/2022/01/31/addin...ation-sitemap/
At the moment unfortunately it’s not possible to put PCF directly to the SiteMap but I found a workaround you can use that I described in this post. Entity In order to place PCF Control to the Sitemap, you have to create a “stub” entity that will serve as a placeholder for a PCF Control. ...
The post Adding a PCF Control to the Dataverse Application Navigation (SiteMap) appeared first on Andrew Butenko's Blog.
butenko.pro: JS: Access values of fields located on the “Form Component” PCF Control Blog bot Dynamics CRM: Blogs 0 21.09.2021 06:41
butenko.pro: PCF: Adding external handlers to controls Blog bot Dynamics CRM: Blogs 0 31.08.2020 19:13
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics 5.0 Service Pack 1 Blog bot Dynamics CRM: Blogs 0 04.06.2010 12:51
Права на добавление объектов в Дизайнере Cyr NAV: Администрирование 10 13.06.2009 21:27
Часовой пояс GMT +3, время: 12:23.
